Old 02-15-2018, 07:38 PM
Cobra Make, Engine: A&C 427 s/o
Default cam lift question
does anyone know how much cam lift can you go with on a 427 s/o with stock pair of medium rise c5ae-f heads?
Old 02-15-2018, 09:30 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
There may be some things that rule:
1. Pistons - dish to domed
2. Deck height - stock to milled, how much and all that goes with that.
3. Heads - stock to bonzi CNC.
4. Block - stock every day mill to "something special"
Why not do the "silly putty" trick? Do a rough put-together and put silly putty on the piston. Cut it with a knife and see what you have. Then give yourself 15 percent ( 10 if you are risky ).
Then again, you could get a dial indicator...measure.
There may be other recommendations...think those over.
Old 02-17-2018, 09:16 AM
Just considering the head, it is where the valve spring coils bind. I cannot remember the recommended minimum clearance, but with the valve fully open, you should be able to slide a feeler gauge between all coils. The tightest spot should be at least some number.
The clay measurement on the engine described above should always be checked.
Another alternative is to set a piston TDC. Set a head on with no valve springs on that cylinder. Then measure the valve travel from touching to closed. Both intake and exhaust. This will get the total clearance at TDC, provided the head is torqued down with the gasket that will be used. Then you have to know the cam lift at TDC. This method is good for choosing a cam, but I would still check it with clay before assembly.
After 60 years there is likely no such thing as a stock head. Ford made so many head changes over the development of the FE and with union issues I would not count on all heads of a casting number all having the same valves, springs, retainers, etc. Each head should be checked individually. There is likely no one number for maximum lift.
