Old 04-27-2018, 12:08 PM
Cobra Make, Engine: SPF #373,Shelby FE Alum Block #077, 488 stroker, Tunnel Port, Dual-TMP DP Holleys
Default Shelby Alum Block rear main torque specs
ARP lists 110 lbs final torque for their 1/2" main studs. Wondering if that applies to alum FE block too or cast iron only??
Thanks Ray
Old 04-28-2018, 10:05 AM
I will not advise on the Toque in you application, but you need to make sure that the threads on the fastener are the right length, when dealing with aluminum.
For a steel bolt I believe a rough rule of thumb is one bolt diameter of threads is needed to hold maximum torque. Aluminum being softer and it creeps (flows) over time requires quite a bit more threads. I recall some years back a fellow used a bolt kit for a cast iron engine, and the threads pulled out of his block eventually.
My advise to you is to get your data from an expert who builds these engines.
Old 04-28-2018, 12:46 PM
I was hoping to get a response from one of the engine builders on this forum. I can't think of a forum with any more Shelby alum FE block experience than what I see here. If I can't get an expert opinion before Monday I will call Gessford. Thanks for your response Dog.
Ray
Old 04-29-2018, 07:52 AM
There is a website that is nothing but FE guys, but I forget its name. Seems like FE Forum, but I do not know the exact name.
Brent may stop in but if not, he has his own website. I'm brian dead on that name as well. I just got back from a work trip to France. 6 weeks of 10 - 11 hour days and my brain is a bit numb right now.
Old 04-29-2018, 08:02 AM
MOTORHEAD's Avatar
It's Brent Lykins ( Lykins Motorsports) who recently said he was building no more alum block fe's, but he would still know the numbers, as would Barry Robotnik or Jim? lefevers.
I have the spec sheet from shelby in my engine paperwork. I'll dig it out and post.
"When Injustice becomes Law,
Old 04-29-2018, 09:23 AM
MOTORHEAD's Avatar
Here's the specs from Shelby:
Main stud (all) 85 lbs/ft with moly lube
side bolts 38 lbs/ft " " "
head studs 10 lbs/ft " anti seize
head nuts 95 lbs/ft " moly lube. This one may be incorrect, I think I saw where
Barry R said he was using 85 ft/lbs on the head nuts, but I would check with him first.
