2Likes
2
Post By Karl Bebout
05-28-2018, 07:10 PM
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Plug wires
Well the metal conductor (part that goes over the tip of the plug) pulled out of my #6 wire when I pulled the wires to do my recent valve cover gasket repair. I bought a set of the MSD “superconductor” 8.5 mm wires because they had an advertised 40-50 ohms per foot resistance. Installed them yesterday on my 482 FE and I have to say they really work well. Car ran great before but even better now (I had a good set of 8 mm wires before). The set was not cheap but they seem to be well made and work well.
05-29-2018, 08:38 AM
Cobra Make, Engine: BDR #509, 347 S
Good to know. Currently running Accel 8.8 300+ Ferro-Spiral Race Wire... and they are 150 ohms per foot... and slightly more expensive to boot...
05-29-2018, 10:07 AM
I know some people recommend against it, but I'm a firm believer in dielectric grease on the contact and porcelain of the spark plugs. Since I've been using it, I've not split one boot or pulled the wire apart. I also use it on the distributor cap end of the wires. Just makes any disassembly much easier and safer. I've carefully looked at the plug wires, with the engine running, and in darkness and have not seen any arching. I've also never gotten bitten when adjusting the distributor for timing. I'm sold. My 2˘ worth.
Karlos
05-29-2018, 01:52 PM
Ditto. Same here. Just curious... what reasons are given for not wanting to use it?
05-29-2018, 04:39 PM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
I completely agree with your observation of the MSD plug wire performance. I had been running Accel Pro Stock wires on my FE and didn't think that they required replacement. However, I wanted reroute some of the plug wires and elected to use the MSD universal kit that I could cut to the length I required. After making the change you could actually feel the difference in performance which surprised me. I was curious so I cut two identical pieces of the MSD and Excell Pro Stock and tested them for resistance. Don't recall the exact numbers but the MSD wire resistance was a small fraction of the Accel. Highly recommended if you are upgrading your plug wires.
05-29-2018, 04:47 PM
Must have had some faulty wires.
I've have run the Accel 150 ohm wires, and the MSD wires.
I doubt whether anybody could tell the difference between 50 and 150 ohms, considering normal stock wires are 3k - 8k ohms per foot.
05-29-2018, 06:24 PM
ct
Same here, I use it heavily inside both ends of the wires and on the coil terminals
05-29-2018, 06:49 PM
ct
I also used the MSD Ultra 40 cut your own. I took a lot of time because I wanted it to look really neat. I did have issues with arching in a pitch black garage. I kept adding more and dielectric grease and it helped a lot. The fixed turned out to be tightening up the plugs believe it or not. The forum help out a lot with this. The plugs were tight, just not tight enough I guess. Path of least resistance was causing the arching
05-30-2018, 06:18 AM
The 5th paragraph (Disadvantages) of the link is informative, as many people consider dielectric grease to be conductive.
Dielectric Grease
05-30-2018, 06:40 AM
Dielectric Grease
Umm, close but not quite. While dielectric grease itself is non-conducting, using it on electrical contacts can improve their reliability by blocking corrosion and oxidation. The metal contacts still complete the circuit, the grease surrounds the contact points to reduce oxidation. It can also prevent arcing between contaminated insulators like plug boots and ceramics.
https://en.wikipedia.org/wiki/Silicone_grease
05-30-2018, 08:12 AM
TN
Cobra Make, Engine: '65 Shelby Cobra, '66 Shelby GT350's
Battery terminals/posts are another excellent spot for dielectric grease for the same reasons stated above.
~ Steven
6S1806, 1966 Shelby GT350 B/P Race car.
6S246, Shelby GT350 "carryover"
6S1745 Shelby GT350
06-16-2018, 08:29 AM
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Just did this deed and will report that the Taylor Made (get it: tailor made) cables are much too long and look sloppy, tho' presumably they work OK. Bought the MSD kit (31383) and it fits some better, but if you want to do it as neat as possible, the poster who said make your own from the MSD universal kit, is corrrect. It is the way to go. I love the little device that MSD sent to neatly attach the plug wire number identifiers. Very cool and easy to use. steve
steve meltzer
"I may be wrong, but I'm never in doubt"
06-16-2018, 08:56 AM
OH, yeah, and one more thing. At least on my KMP #174, the plug boot on #6 and 7 is so large as to interfere with the throttle mechanism. Not so on my old Accel wires. I very carefully cut those two boots down so that the throttle mechanism doesn't strike those two boots. (this is on the MSD kit 31383) steve
steve meltzer
06-16-2018, 10:58 AM
I have had lots of frustration trying to determine proper part numbers for a proper fit when it comes to these aftermarket ignition cables for my Ford engines, including the FE and 351W. Nothing fits properly (not even close), so I have given up and now only use the "trim your own" style.
I did have a good experience with the FE wires in regards to fitment on the Carroll Shelby signature cables that I sourced from DenBeste. The coil wire may or may not work depending on your application.
06-16-2018, 11:01 AM
Bas
Cobra Make, Engine: Hawk 289 USRRC, 302 Ford
I also use the MSD Superconductor kit and the quality is worth the price. I measured each cable after crimping and found the resistance very consistant per feet.
I use WD40 to prevent corrosion, no issues so far.
06-16-2018, 06:36 PM
Dielectric grease is non-conductive but I used it for years without any conductive issues. But I then discovered No Ox (stands for no oxidation) which is an electrical conductor grease with low dielectric properties. It's specifically made for electrical connections. So I've switched over to it for electrical connections now.
I have a WiFi security camera system around my house with 12V power from attic receptacles and I've had a heck of a time keeping the cameras on and sending data to the recorder. One would fall off line after just an hour or so and another every day or two. I finally went around and put No Ox on all the antenna connections and all the 12 volt power cord extension connections and the plug blades at the receptacles. It's been a month now since I last lost a camera connection. Definitely good stuff.
06-16-2018, 10:06 PM
I have been happy with Taylor wires because I think their spring loaded spark plug connector is better. I've never measured their resistance but with the superior connectors, a nice thin coating of dielectric grease and careful routing, I've not had any arcing issues. The spark plugs, plug the hole and make a spark. Life is good.
Karlos
