Old 07-01-2018, 06:15 AM
Default E3 Spark plugs
Hi everyone, please help settle an argument on my 427 side oiler. I have a 1965 427 side oiler w/428 crank (stroker). Stock cast iron heads w/10-1 comp ratio, ss valves, MSD ignition, crowler cam (16331) 551/565 lift, 2 600 cfm Holley carbs. all set with 24 BTDC timing. Currently I'm running Autolight AP-45 plugs w/.045 gap. I want to try putting E3 spark plugs on to see if there is any noticeable difference. Is there any recommendations from anyone? Also any noticeable difference in your engine performance?
Thanks for your time.
Old 07-01-2018, 08:57 AM
The Autolite AP45 (single platinum) are good plugs. The APP45 (double platinum backstrap and electrode tip) wear a bit better. The E3.72 would be your replacement.
https://e3sparkplugs.com/parts/?part=E3.72&cr=1
I have no personal experience with the E3 product. But if the Spark Plug indexing school of thought is valid, the E3 plugs with 3 ground straps have 66% more spark kernel shielding than a standard plug. Which is not a good thing.
I'm thinking an open spark kernel must be a good thing or else Autolite would not modify the AR (Racing) series of plugs with cut-back (exposes the electrode) ground straps.
Autolite Racing Spark Plugs - The Best Performance Spark Plugs
https://images-na.ssl-images-amazon....L._SL1500_.jpg
From Moroso. http://www.moroso.com/sites/default/...eed%20News.pdf
Old 07-01-2018, 09:13 AM
FWB's Avatar
FWB FWB is offline
actually the 45 is not the right plug anyway, it is whats available closest to the right plug. its a step hotter than the preferred plug. cross the BF 32 which is the right plug, to what your thinking of using, don't use the 45 as your baseline
Fred B
Old 07-01-2018, 09:29 AM
The Motorcraft BF32 and Autolite 45 or (AP45) are the same per the Autolite site.
Autolite - Online Parts Lookup
When I lookup a 65 Galaxy 500, 427 (7.0L) it recommends a 45 or AP45 plug.
Old 07-01-2018, 05:52 PM
FWB's Avatar
FWB FWB is offline
i know it is what they say crosses but the AP 45 actually crosses to the BF42
the 32's are unavailable. the 32 was the plug of choice,
would you as a spark plug manufacturer say sorry we don't have a plug for your engine, no, you cross it to the closest you can and say this is the plug.
buy a set of BF32's off ebay and try them
Fred B
Old 07-01-2018, 01:23 PM
Karl Bebout's Avatar
Hi Glass, I haven't felt the need to squeeze every last bit of power out of an engine since I quit racing, decades ago. I did the indexing thing and cutting the ground strap back hoping for that last ounce. Even went on a diet before the season started.
If the ultimate is what you're after, drop the bucks and give the E3s a shot. Otherwise, just stay with the Autolites. They will plug the hole and make the spark, just fine.
Karlos
