January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree3Likes
  • 2 Post By eschaider
  • 1 Post By FWB
Old 07-24-2018, 05:31 PM
Registered User
Default No casting number 427 date 2 l 17
I need help trying to figure out what type of 427 engine I have. I was told it was a side oiler but I’m not familiar with the 427’s. This engine came with a 1967 Mustang S code 390 car that I had purchased some time ago. It’s missing the carburetors but have a factory 67 Shelby GT500 C7ZX-9425-A intake manifold. It has screw in freeze plus and a 427-26 casting inside the engine block. The caring date appear to be a 2 L 17. Thanks
Old 07-24-2018, 08:54 PM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
A side oiler will have a pipe plug in the front of the block. It is above the oil pan and outside the timing cover on the driver side. This plug covers the hole where the oil galley along the side of the block was drilled. If you have this plug, it is a side oiler. If you don’t, it is either a center oiler or top oiler.
Chris
Old 07-25-2018, 01:54 AM
Registered User
Chris, here is picture of the engine block. Thanks for the info. Not really sure about anything else since I can’t find any other numbers other than the date casting. I’ll look closely again. These pictures were taken by the former owner before the engine was put together. I’ll look again once I have taken it out for a complete inspection. I think the intake manifold was an add on since the block appears to be a late 1962 block. Thanks
VName:  F4ED5E5F-6B5C-412E-9125-E99EC697E134.jpg
Old 07-25-2018, 04:33 AM
Ron61's Avatar
I can't tell from the picture but on a side oiler you should have a small rib running along the drivers side I think it is and down low on the side of the block. That would be the oil passage.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-25-2018, 06:35 AM
Cobra Make, Engine: Scratch-built 427 MR
Marine or irrigation block. Not a side oiler. Bill.
Old 07-25-2018, 06:59 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Likely 1972, not 1962. Service block or industrial application.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 07-25-2018, 08:09 AM
Senile Club Cobra Member
Many more 427s were made for Ford Industrial Engines (now "Power Products" than were EVER made for cars! LOTS of 427s went into inboard boats and watch out as if it was a twin, the second motor was reverse rotation!
rick@autoventureusa.net
Old 07-25-2018, 08:28 AM
Default Side-Oiler Bulge
For comparison.
Old 07-25-2018, 09:16 AM
eschaider's Avatar
The bottom pic in post #3 is quite interesting. The block appears to be a side oiler casting that was not drilled for side oiler oil delivery.
The oil galley bulge along the side of the block above the side bolts is clearly visible in the bottom pic of post #3. It appears that Ford ran the cutter for the engine mount boss machining operation deeper than normal to cut into the casting provisions for the oil channel. Above each side bolt you can see some or all of the associated boss that would have been drilled to the main saddle for oil delivery.
Quite an interesting block! Perhaps it was from the end of a side oiler casting run and the factory was producing top or center oilers for say industrial applications? It is possible someone made the decision to machine it as a regular block not withstanding its side oiler casting heritage for expedience instead of using the non side oiler casting ...
Ed
joyridin' and 67S390 like this.
Old 07-25-2018, 10:26 AM
Cobra Make, Engine: kmp927
Handy guide to help
http://www.erareplicas.com/427man/engine/partnums.htm
Old 07-25-2018, 06:52 PM
FWB's Avatar
FWB FWB is offline
its a 1972 marine block......not side oiler, hydraulic block oils like a 390
67S390 likes this.
Fred B
