Like Tree1Likes
  • 1 Post By patrickt
Old 08-14-2018, 02:12 PM
FUNFER2's Avatar
Default Which Steel FE Crank ?
Out of the top FE cranks, which are most used quality cranks ?
Not for racing or high RPM's, so a quality made and machined although cast's are cheaper, over a very nice forged crank, like a Crower, Callies......(beautiful, but....)
No billet's needed either. lol
I assume, it will be a stroker engine, but not positive yet. Street/strip use.
Scat, Eagle etc.
Regards,
Kevin
Old 08-14-2018, 08:41 PM
RockBit's Avatar
Cobra Make, Engine: ERA #812 427/482 FE
Kevin - When Brent built my engine I asked him to use a forged crankshaft. I’m not a fan of casting from my professional life. He used a Scat forged piece. I drive my car on the street, no racing, but do get spirited occasionally. No complaints.
Chris
Old 08-15-2018, 03:21 AM
Dimis's Avatar
If its scat vs eagle for fe build? Its scat every day of the week.
Sadly this forum alone has a history of eagle cranks going pop...
Old 08-15-2018, 04:00 AM
FUNFER2's Avatar
I thought that people say it the engine doesn't see sustained high RPM as a racing motor, it's overkill and you'll pay at least $400 (+) extra for a forged. I'd rather have stronger
one but... ?
I too have heard that about Eagle.
Regards,
Kevin
Old 08-15-2018, 07:44 AM
Danr55's Avatar
A forging is a homoginous blank that is hammered to form, heat treated, and ma hined/ground to form. This creates a very small.grained product that is stronger by nature than a poured/cast product the may or may not be exactly as designed. With the forging, the argin of error is much smaller than with a cast product. If you are concerned with liability of failire, go with the forging. If you want to save money, go with the cast product.
Dan in Arizona
CCX3209
Old 08-15-2018, 10:24 AM
Cobra Make, Engine: Kirkham #259
https://moldexcrankshaft.com/
The best..Moldex
Morris
Old 08-15-2018, 11:38 AM
FUNFER2's Avatar
Originally Posted by Morris View Post
Their site is off-line for a while. What is thier apx price ?
Regards,
Kevin
Old 08-15-2018, 04:18 PM
IIRC, a Moldex steel billet, chromoly crank costs about 50% over what a SCAT 4340 costs, but it's the strongest crank available, and, you don't need it. Not by a longgggggg shot.
Old 08-15-2018, 04:20 PM
DanEC's Avatar
When I had my FE built about 7 years ago, Keith Craft seemed to be fully committed to SCAT cranks which is what I have.
ERA 782 Running
Old 08-15-2018, 04:55 PM
From Barry R.'s book: In four years of testing and abuse, I have yet to break one of these [SCAT] cast 4.250-inch cranks—at power levels exceeding 750 hp. Intuitively, this has to be approaching the design limits of the material, though, and an alternate should be considered at that power level. … and FWIW I put a SCAT in mine as well.
Old 08-15-2018, 06:17 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Barry R. built my engine and used a 4.25 cast crank.
https://www.enginelabs.com/news/vide...es-of-fe-fury/
Old 08-16-2018, 04:24 AM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
I cant any info on the crank in the article?
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
Old 08-17-2018, 05:47 AM
Fair enough. I see now that it only mentions the 4.25 stroke. In any event, it is a SCAT cast stroker crank that was recommended by Barry R. for a targeted 550+ HP / torque street engine. For me, Barry's endorsement is all I needed.
Old 08-17-2018, 01:21 PM
I would be thinking the same...he has a great reputation for sure!
Old 08-17-2018, 02:49 PM
FUNFER2's Avatar
Is the 4.25 bore safe for the 428 ?
I know the stroke can be 7.50
This looks like a sound kit.
Summit- $950
Bore (in): 4.280 in.
Crank Forged 4340 steel
https://www.summitracing.com/parts/s...gaAgn4EALw_wcB
Regards,
Kevin
Old 08-17-2018, 02:57 PM
No, but it's just fine for the stroke.
AC Ventura likes this.
Old 08-17-2018, 03:20 PM
FWB's Avatar
FWB FWB is offline
Summit- $950
that's a chevy stroker kit
Fred B
Old 08-17-2018, 06:24 PM
FUNFER2's Avatar
He wants a stroker for street fun with a lumpy cam.
The block he bought has been cleaned and bores checked, and all is fne to be continued.
Regards,
Kevin
