Old 02-04-2002, 05:08 AM
Cobra Make, Engine: Unique 427 S/C 428 cid 430 hp
Default Breather Question
Hi all,
I have a 428 in my Unique. It has a Weiand intake. At the top back of the intake is located a rubber plug where I add oil. I bought one of those fancy chrome breathers that I want to mount in place of the rubber cap. Only problem is there are no threaded holes around the rubber plug to secure the tall breather. Any ideas ?
Tnx,
Jerry
Old 02-04-2002, 09:46 AM
Hello Jerry,
Check with Gessford Machine they will set you up.George is
very good at helping with any thing Cobra and or FE.
Phone number 1 800 829-3448 Have a good day.
Race Smart-Race Safe
Mikestang
Old 02-05-2002, 04:18 AM
I am hoping George will see this post as I hate to bother him at work.
Old 02-05-2002, 09:49 PM
Default Weiand Intake info
Hi Jerry...we run into the same thing with the Edelbrock intake....
I'll direct you to some recent images and the pictures will show you the way....
(1) New Intake with NO rear hole
(2) The Dove PCV Plate for a pattern
(3) Drill the two bolt holes and then tap them
(4) In the case of the Edelbrock you bore the hole for the lower breater canister.
(5) The Dove Plate installed with a PCV valve
The Weiand has the material to be drilled and tapped too...
If you need more help...you can call me at work....if you're worried about taking my time up on questions...just call the regular number 402-463-9844.....
What's Big Mike doing on this page....you ought to see what he's building.....I will probably own him some free work for this advertising!!!!
This is his Danny Bee's Dry Belt Drive we're installing....
Have a great day!
George
Old 02-06-2002, 04:51 AM
Thank you George. I figured I could use the breather itself for the pattern. The big center hole is there already and all I need to do it tap it for screws. My question is how deep should I drill and tap ??
Bottom tap or taper tap ?? Any suggestions on what size screws.?. I,m not a real expert on taping and could use any advise anyone has to offer
Tnx,
Jerry
Old 02-10-2002, 03:39 PM
To the top. George, I clicked on the link for bolt taping but there was no page. Hope, I hear from U guys. I can be dangerous with a drill and tap.
Old 02-10-2002, 06:23 PM
computerworks's Avatar
Default correction
...corrected link for George's step-3:
http://www.gessford.com/projects/ima...5EDEPCV-03.jpg
Old 02-12-2002, 08:32 PM
Default Breather Fastener Question
Jerry....use a 5/16-24 bottoming tap, use a letter I drill...should go about 3/8" deep if you have that much depth in your casting....good luck.....
George
Old 02-13-2002, 09:38 AM
Thanks George.
Old 02-18-2002, 10:59 AM
Default Thank You George !!
George,
Did exactly what you recommended and I now have one fine looking breather . Tnanks again.Jerry
Old 02-18-2002, 09:15 PM
Default Breather
Hi Jerry...glad it worked out as planned......
George...
I probably have a pictures of about everything we do...somewhere on one of my web pages....at over 300 Mb I'm having a hard time finding some of the images these days....
Regards, george
Old 02-19-2002, 05:52 AM
Clois Harlan's Avatar
Default Hey George?
Do you have a photo of the finished intake w/ the neck and breather installed?
I hate pulling my valve cover breathers out to fill my oil.
Clois Harlan
"Let's roll"
"Be part of Something Good
Old 02-19-2002, 08:17 PM
Default Breather
Hi Clois...I don't ever use the breather type mentioned above....was just helping with the hole pattern etc...
This is the PCV valve we install with the baffle basket under it...
http://www.gessford.com/projects/ima...5EDEPCV-06.jpg
George
