Like Tree3Likes
  • 3 Post By blykins
Old 03-11-2021, 12:38 PM
Default Confused
Hello Guys, new guy here. I'm a bit confused by all the terminology regarding the cams, lifters and rockers on the FE engines. Flat tappet, solid lifter cams , hydraulic lifters, roller rockers, adjustable this, fixed that ,etc. I've been reading a lot, but still not completely understanding. Based on the info below, can you tell me exactly what this is? Would it be a solid lifter cam with solid lifters and adjustable rockers? No rollers or hydraulics.
Block - 427 side-oiler, 4.250 bore
Crankshaft - C4 steel with plugs
Rods - Ford C6 Lemans
Rings - Hastings Molly
Pistons - Keith Black high performance KB199-20
Engine bearings - Federal Mogul
Cam- Elgin solid lifter E962P Pro Stock
Oil Pump - Melling High Volume - ARP Oil Drive
Oil Pan - Canton 8 qt. & pick-up
Heads - Edelbrock aluminum #6008 w/ oversized valves & seats, fully ported & polished
Intake - Blue Thunder 2 4V aluminum intake, port matched to heads
Carburetor - (2) Holly 600 cfm, Stellings air cleaner, K&N filters
Compression - 9.8:1 (use 93 octane)
Rockers - Ford adjustable rocker arm assemblies
Distributor - HP modified electronic with centrifical advance
Ignition - MSD 6AL w/ buillt-in rev limiter and blaster coil
Water Pump - Edelbrock aluminum high volume
Timing Chain - Elgin double row
Flywheel - Ford Steel 0 balance
Clutch & pressure plate - McLeod
Pulleys - March billet aluminum
Bellhousing - Lakewood Blow Proof
Sorry for the dumb question, but although I was a machinist by trade, when it comes to engines, I consider myself more of a parts changer.
Old 03-11-2021, 01:59 PM
I know that cam. It's made by Elgin Industries and it's basically a clone of the Ford 427 dual four barrel carb cam (not the single four barrel). It is a solid flat tappet cam and has a lift of .524 with a lash of about .024 gives you a net of .500 -- here's a link to when Amazon had them. https://www.amazon.in/Elgin-Industri.../dp/B012ZYYYWI That cam would have a variety of Ford numbers assigned to it over the years, but that's what that cam is. A lot of people like it.
Old 03-12-2021, 08:28 PM
Someone please correct me if I'm wrong, all sideoilers have solid lifters with flat tappets.
Old 03-12-2021, 08:40 PM
The only general rule with FEs, including side oilers, is that there is no general rule that is always right. Especially 50+ year old engines that have been worked over a couple or more times.
Old 03-13-2021, 12:56 AM
Cobra Make, Engine: Cobra FF5/BBM 482
68 side oiler blocks were hyd
Old 03-13-2021, 06:29 AM
undy's Avatar
At 4.25" bore without sonic cylinder wall test provided by a seller I'm be very Leary about purchasing it. The OEM 427s were notorious for core shifting.
Too many toys?? never!
Old 03-13-2021, 04:20 PM
A sonic test is always prudent, but 4.250" is only .017" over standard bore. I've never seen one have an issue there.
