Old 03-11-2022, 08:00 AM
bomelia's Avatar
Default 428 Heads
Hey all. For the past year I have had Edelbrock heads on back order with Summit. Just go another notice of a 3 month (more) delay. So I cancelled it.
Any ideas where I can find some?
Old 03-12-2022, 07:01 AM
55312's Avatar
Try Keith Craft
Old 03-12-2022, 10:32 AM
ERA174's Avatar
Cobra Make, Engine: ERA 427, 482ci sideoiler
Mike,
If you're not ready to drop the motor into a completed Cobra, I would suggest waiting to see if the supply chain issues improve. If the motor is holding up the completion of the project, consider trying to locate cheap low performance original cast iron heads to get rolling and swap them out down the road for more desirable units. If you haven't tried already, look on the Ford FE Forum, 332-428 Ford FE Engine Forum you may find something there.
Old 03-12-2022, 01:31 PM
MOTORHEAD's Avatar
Mike; I was in your position a year ago. ordered a set of Trick flows with long lead time, then found a used set . Had the engine back together , then the trick flows showed up !
I sent them back.
Summit sells them, price is not bad. Did you consider them ? Brent Lykins swears by them.
"When Injustice becomes Law,
Old 03-12-2022, 05:04 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Brent used Trick Flow on my FE build. I think they are made by Edlebrock and flow much better.
Old 03-13-2022, 12:53 AM
Question Well...
did you ever get your Unique, Mike? Haven't seen you over there in quite a while... in fact, was wondering, not too long ago, what was going on to you.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
