Old 03-27-2022, 05:26 PM
Cobra Make, Engine: Everett Morrison FE 428
Default FE engine builders
I have a 428 bored .030 with performer heads 6006 from late 1990s, when the engine was completed comp ratio came in at 9.9-1 later I had an issue and the heads cut .004 . The head Literature says chambers are 72CC and each .005 cut reduces chamber volume by 1CC. Can anyone (Brent) tell me what comp. Would now be? Thank you
Old 03-27-2022, 06:21 PM
Mahle provides a compression calculator.
You will need several specifics from your
engine build documentation to complete.
https://www.us.mahle.com/en/motorspo...SAAEgLcJfD_BwE
Old 03-28-2022, 10:44 AM
If it was exactly 9.9:1 before and you don't had heads cut .004" then you approximately knocked off a cc, which would raise your compression ratio about .1 of a point. So you're still at around 10:1.
Old 03-28-2022, 06:47 PM
Thanks guys
