02-17-2002, 02:16 PM
Anyones 428 Engine Spec`s
To those Guy`s running 428 in there cars, What is your total spec? What cams,heads, comp ratio do you have. Lets have some real detailed replies please guy`s.
thanks
02-18-2002, 09:10 AM
OK
Spec's
428 CJ bored .060,
JE Pistons 10.1 : 1 compression
Fed Mogul Rings and bearings
Crane .216-.228 and .533 .533 cam
Crane springs w stock hydraulic lifters and stock rocker arms
Edelbrock Aluminium Heads
Ford Medium Riser Alum Manifold
HOLLY 750 cfm Carb
Holly Red elec fuel pump and regulator
MSD Distributor
MSD 6AL W/ Blaster Coil
Taylor 8.5 mm plug wires
Champion RC12Y #71 Plugs
"Let's roll"
"Be part of Something Good
02-18-2002, 09:21 AM
The longest build.....
KS
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
428 details
1968 Ford 428 Police Interceptor block
Sealed Power .030 forged pistons (yields 10.5 to 1)
Factory 13/32" rods
Stock crank
ARP fasteners
PI heads with CJ stainless steel valves, ports mathced to intake and headers
Police Interceptor intake
750 cfm Holley with Proform main body
MSD 6AL, Petronix electronic ignition and coil
.562 with .302 duration hydraulic lifters
Sealed Power valve train, hd oil pump, timing set, rings, etc
Edelbrock water pump
Carter fuel pump
Sealed Power roller rcokers with HD shafts and supports
Autolite 45 plugs
02-19-2002, 05:55 PM
66 428 .10 over
cast pistons/crank
approx 10:1
edelbrock alum heads-out of the box
edelbrock rpm valvetrain hyd 236/236 .575
blue thunder intake
48 idas
msd 6al with blaster coil
stock oil pan with modified oil passages
hi-volume water pump flo-cooler
remanuf. shafts with harland sharp roller rockers
holley blue mechanical fuel pump
remanuf. dampner from dampner dudes in ca
02-19-2002, 06:01 PM
Waderaces,
I have a approx the same set up as you except my cam is 224/224 .510 with comp cams roller rockers, 48 IDA's , ported and polished Edelbrock alum heads 10:1 etc. What are your choke sizes and jetting?
02-19-2002, 08:03 PM
Wade,
I have a similar set up just getting started for a new EM on the way. Should be here in a few weeks.
My FE is a 427 Center Oiler.
My IDA's are coming from Inglese.
Any tips on the Webbers or the EM?
02-19-2002, 09:08 PM
Block: '67 428 CJ
Heads: 428 Cobra Jet
Valve seats: hardened 5 angle grind
Valves: 2091660 REV stainless
Bore: 4.155 torque plate honed .005 piston to wall clearance
Pistons: J.E. #8043 4.150"
Cam bearings: FP33 Durabond Hi-perf
Rings: Speed Pro E243K+25
Crank: 1U (428 casting #) by Accu Crank in Arkansas
Rods: 428 Cobra Jet C7AE-B
resized to 2.5910 w/ ARP bolts
Timing chain: Rollmaster #TC-6
Cam: Crane 248/248 duration, .521" lift
lobe 602/602 108deg lobe center
Valve springs: Comp Cam 936-16
Valve spring retainers: Comp Cam 742-16
Rocker arm studs: custom U-stands for end supports
Lifters: Speed pro AT-2000 solid mechanical
Water pump: Edelbrock
Intake: Edelbrock Performer RPM
Valve covers: Cobra LeMans aluminum finned
Distributor: stock hei with lightened springs and centrifugal advance
Ignition wires: Holley 9mm Annihilator Laser Shot 50
Coil: MSD Blaster 2
Ignition module: MSD 6A
Carburetor: Holley 750 cfm, vacuum secondaries, worked to flow 830 cfm
Clutch: Centerforce dual friction
Air filter: K & N with full flow top
03-05-2002, 03:02 PM
my 428 specs
4.130 + .030 TRW forged pistons,.011 deck height, heads C80e-N milled .030 bumps removed from intake and exhaust ports. roof of intake port opened up to match gaskets,CJ exhaust manifolds, F427 intake with center divider removed down to l/4" from floor, Heat closed off to intake, cam Lunati 228/235 @.050 .545 lift installed 4 degrees advanced. MSD 6, Holley red pump, with above and stock 750 Holley (with straight leg booster) max power was reached @5900rpm. Since I specialize in race Holleys I put in a 780cfm (3310-1) with DOWN LEG Boosters, enlarged primary venturi to l.42 to match secondary,milled off choke horn, rejetted to #71/#77 with .110 needles, Power valves 5.5, Powervalves orfice opened up to .060 (two in front and two in secondary) .031 shooter, raised fuel level 3 flats above bottom of sight plug. car now literally screams to 6300...I shift there only because I value my 4" crank.
69 Mach 1,428SCJ trak pak,4 speed, 3:91 axle restored
03-06-2002, 08:08 AM
TN
Cobra Make, Engine: Unique 427; 428 Mid South Gear
My 428; gets better with mileage
....don't forget the Tilton starter, or you'll get embarrased
....don't forget the turkey pan, helps a little to keep heat out of carb
....don't forget the Canton road race pan!!!! or that precious crank and rods will suffer on the road coarse---cut a path for the dipstick!!!!!
....Ford windage tray
....040 over all balanced and blueprinted
....all ARP new
....forged eyebrow pistons about 10:1
....comp cams 270H hydraulic, don't cam in timing!!
....True Roller timing
....edelbrock heads out of the box complete
....Edlb. performer rpm intake, lettering removed
....Ford Duraspark II ignition with MSD billet distributor and wires; combo works great---9 degrees initial---limit stop for 35 degress total---forgot the springs but advances fast
....old Holley 780 vac second--stock with 8.5 and 6.5 pvalves
....Edelbrock water pump--Ford reduction pulleys
....stock rocker stands, hardened shafts, crane adj. rockers
....oiling system has been tuned top to bottom by EXPERIENCED FE builder--HV HP Melling pump
....Carter fuel pump
....I know you want details, but all of the clearances ant tolerances are in a book at home-sorry
Dan Fowler
Knoxville, TN
03-16-2002, 02:27 AM
C6ME block
.030 over
Stock Crank .010 &.010
Crank Internal balance polished & teardroped
Stock rods balanced & ARP bolts
Cast pistons 10:1 & Federal Mogal moly rings
Federal Mogal bearings
ultradyne cam 221/221 duration & .533 lift
ford SVO pushrods & crane anti pump up lifters
edelbrock roller timing chain set
HV oil pump w/ ARP fasteners
ARP EVERYTHING
Edelbrock heads
Harland Sharp roller rockers & billet spacers & stands
.090 oil restrictors
cobra 427 polished finned rocker covers
polished edl water pump w/ edl removed
march pullys
romac dampner
polished alt brackets
ORIGINAL FOMOCO '67 med riser 2X4 intake
Holley BJ/BK 550cfm vac secondaries
custom billett fuel log & stainless fuel hoses
holley chrome fuel pump
dove pcv valve in rear of intake
avaid oil pan per original
msd 6al
msd pro billet dist & coil
Taylor wires
felpro gaskets
polished timing cover
& all the help in the world by George Anderson @ gessford machine
All built by me going into ERA #626
03-16-2002, 06:40 AM
1969 428SJC
I have a 1969 special order Torino Daytona Cobra that came with the 428 SJC motor which has all NASCAR running gear. The motor was bored .060 over by the dealer. It came from the factory with 427 lower end including NASCar rods, 427 heads and other goodies. It has an Isky 312 duration solid lifter cam with .630 lift and 93 degrees of duration. It came with an aluminium high rise intake with an 850 Holly double pumper hogged out to around 900 cfm. All I have changed was to replace the original Mallory ignition with a Jaclbs as I like them and the Mallory kept going bad. The motor is a little radical for crusing around town and starts to smoth out at around 3,400 RPM. I got the car brand new in February 1969 and have had it ever since and it has been great.
Ron61
04-11-2002, 11:36 AM
Here's the specs on my engine:
67 428 block bored .030 over
Stock Crank .010 &.010 w/external balance
Forged TRW pistons 10.5 :1
Clevite 77 bearings
Edelbrock heads w/.090 oil restrictors
Fel-Pro head gaskets
Crane cam 226/226 duration & .537 lift
Crane hydraulic lifters
Crane 3/8 pushrods
Cloyes double roller timing chain & gear set
Melling HP/HV oil pump
Crane 3/8 oil pump drive shaft
FPP billet spacers & rocker shaft end stands
Cobra Lemans polished finned aluminum rocker covers
Edelbrock aluminum water pump
Edelbrock Performer RPM aluminum manifold
Holley 4779 750 Double Pumper
Tony Branda finned aluminum 7 qt. COBRA oil pan
Mallory Unilite distributor
Mallory Promaster coil
Mallory Hyfire IV ignition box
Accel wires
Polished timing cover
Polished aluminum power steering pump brackets
Chrome power steering pump
Chome alternator
Chome FE expansion tank
Polished stainless steel mandrel bent radiator tubing
Remote double oil filters
Earl's oil cooler
