-   -   2 Piddly 427 Questions (http://www.clubcobra.com/forums/fe-talk/16929-2-piddly-427-questions.html)
chuckbrandt 05-09-2002 07:56 PM
a) Does anyone know where to buy a new tall water outlet for use with a sidewinder intake. I'm told this one is also used with a tri-power and dual quad. I bought a used on on ebay but it's kinda scruddy.
b) On a Stelling & Hellings air cleaner where is the little blue sticker supposed to go?
And yes, I'm embarassed to waste webspace with such dumb questions :)
Thanks, Chuck
Cobranut 05-09-2002 08:39 PM
Chuck,
There are no dumb questions.
I assume you want the FE expansion tank.
Try Enzo at Finishline or Cobra Restorers. They each sell an unassembled unit which you can have brazed together in the configuration you need at a local radiator shop.
As far as the blue sticker, I'm too dumb to answer that one. :confused: I'm sure someone on here knows.
Later,
chuckbrandt 05-09-2002 08:49 PM
Thanks for the reply...
but here is what I'm looking for. Sorry, I should have done this before.
http://www.chuckbrandt.com/outlet.jpg
Thanks,
Chuck
427Aggie 05-09-2002 08:56 PM
Not sure what thats suppost to be for? I have a sidewinder that I used to run and it has a bung for the temp sender? Is this so you can run a heater with the intake?
Matt
computerworks 05-09-2002 09:11 PM
Re: 2 Piddly 427 Questions
That's a good detailer's question!:confused:
(Alex...I'll take Air Cleaners for $500...)
I looked quickly thru my files:
CSX3166 - has it towards the rear
CSX3229 - has it towards the front
CSX3342 - has it towards the front
...who's correct?
:rolleyes:
Cobranut 05-09-2002 09:26 PM
Ahhh, you're looking for the heater hose outlet.
That looks identical to the one on my intake, but unfortunately I can't remember if it came with it or if I bought it elsewhere. It is a nice gold irridite (sp?) color.
My intake is a Blue Thunder medium-riser reproduction. Check their site for contact info to see if it is available separately.
http://www.bluethunderauto.com/
Good luck,
chuckbrandt 05-10-2002 06:02 AM
Great!
Sounds like new ones do exist! Thanks, I'm on the hunt!
Chuck
chuckbrandt 05-10-2002 06:05 AM
Re: Re: 2 Piddly 427 Questions
...who's correct?
:rolleyes:
So it goes on the top? I noticed the red car on ebay for like a gazillion $$$ has it in front. Front or rear is that roughly where you are seeing them?
Thanks, Chuck
chuckbrandt 05-10-2002 06:08 AM
Yep a heater.
Matt
Can't tell you if it's inlet or outlet but one way or the other it's for the heater. Goes in the hole right behind the thermostat I believe.
Chuck
computerworks 05-10-2002 06:44 AM
1 Attachment(s)
...Front or rear is that roughly where you are seeing them?
Thanks, Chuck
CSX3342:
chuckbrandt 05-10-2002 07:18 AM
Thanks!
Looks good. Thank You,
Chuck
SCOBRAC 05-10-2002 04:22 PM
www.jegs.com
www.summitracing.com
SCOBRAC 05-10-2002 04:28 PM
doh.. thought he was looking for an inlet.. rather than a tank.. Dove makes a polished aluminum one..
chuckbrandt 05-11-2002 04:11 AM
I am looking for an inlet
1 Attachment(s)
But wan't one that looks like this original one.
Thanks Chuck
Mike Norman 05-14-2002 03:44 PM
Hey guys just a thought. From the picture posted above it looks like it might be a PCV vent tube coming out of the breather plate at the back of the intake. Like I said, I may be seeing things but it sure looks like it's going from the intake into the rear of the carb. Just an observation.
chuckbrandt 05-14-2002 04:32 PM
Nope, It's water from the hole right behind the thermostat
Here is a picture of the grungy one installed.
Thanks, Chuck
chuckbrandt 05-14-2002 04:35 PM
1 Attachment(s)
Sorry, picture didn't work for some reason?
CDB
computerworks 05-14-2002 05:16 PM
...will you be having a Heater?
chuckbrandt 05-14-2002 05:38 PM
Sure why not? Wonder what I should get for snow tires? :)
CDB
computerworks 05-14-2002 07:42 PM
...cuz that sure looks like the heater core feed. If you can't find a good lookin' one....plug it.... and stay cool
