Old 05-29-2002, 10:43 PM
Turk's Avatar
Send a message via Yahoo to Turk
Default Dual Plane Manifold!
Did Ford make a 4V or 2X4V Dual Plane manifold for the FE Tunnel Port?
I am getting conflicting information telling me, the only TP manifolds were single plane?
If anyone knows the correct numbers for such a manifold, I would appreciate it. It would make it that much easier to acquire the correct manifold.
TURK
OBAMA IN in 2012
Old 05-29-2002, 10:56 PM
bmalone's Avatar
Turk:
Yes, three manifolds were made for the TP.
1. C8AX-9424-B Alum. 4V single-plane
2. C7OE-9424-A Alum. 8V single-plane
3. C7OE-9424-B Alum. 8V dual-plane
You don't see many of the dual-planes.
I have the 8V single-plane (polished) it is without a doubt, the nicest-looking Ford manifold I have seen.
Bill
Old 05-29-2002, 11:15 PM
Jeff Frigo's Avatar
8V Dual plane? Isn't that defeating the purpose of what a tunnel port is all about? I belive they existed, but why?
Jeff
Mark Donahue
Old 05-30-2002, 10:51 AM
Post Tunnel port 8V dual plane
The dual plane 8V tunnel port was designed for the Le Mans GT 40 effort. The single plane intake lacked the low end demands of the engine coming in and out of the slower hair-pin turns encountered on the European road courses.
Turk, I'm disappointed that you didn't believe me about this manifold! The price for the one I have for sale just went up!!
--Mike
They bend 'em, we mend 'em.
Old 05-30-2002, 11:03 AM
bmalone's Avatar
That's right, TP 1,2,3 at Le Mans. Apparently those 20 mph hairpins were a bit tough.
Bill
Old 05-30-2002, 02:29 PM
Turk's Avatar
Mike,
I am actually hoping someone would tell me and convince me that the other manifolds I already have are a better deal.
If I had known yours was for sale, I would have tried shoplifting it while I was there last weekend.
By the way the car runs great after your magic touch. Ity runs a lot better with all 8 cylinders than it did with 7
Thaks again, you are truly a craftsman.
I recommend anyone who needs any engine work done locally to go see Mike in San Francisco.
TURK
OBAMA IN in 2012
Old 05-30-2002, 03:27 PM
wilf leek's Avatar
C'mon Turk - admit that the only reason you want a dual plane TP manifold is because it's dual - has to be better then single, right?
Wilf
Old 05-30-2002, 11:39 PM
Turk's Avatar
Wilf
If single is good,dual is better.
If a little is enough, more is better?
You should see what I did to our front lawn when I applied my never failing logic to how much Scott's Ferilizer is enough!
I still think more the better, almost on anything.
TURK
The excessive one.
OBAMA IN in 2012
Old 05-31-2002, 12:06 AM
Jamo's Avatar
Super Moderator
Turk
Based on that logic, I have a MUCH better a$$ than you do!
Jamo
Old 05-31-2002, 12:40 AM
Turk's Avatar
"almost on anything".
You have to read the fine print.
TURK
OBAMA IN in 2012
Old 05-31-2002, 11:39 AM
Dsprint2000's Avatar
Default Pat......
If a little gas is good, a lot of gas is better!
dsprint2000 - rubber down
Old 05-31-2002, 12:56 PM
not if you're standing down wind after a big plate of re-fried beans!!
Old 05-31-2002, 03:38 PM
wilf leek's Avatar
Turk - so, on the basis that "more is better", how come you aren't fitting a crate 514?? Or stroking one? And don't try to cloud the issue with fine print - you need all of that you can lay your hands on in the Road Serpents forum. Geez - to think I have been defending you against Dan Semko.
Jamo - bearing in mind in the eventuality that you may one day sit on me if I am unkind to you , I agree about your A$$! It's obviously much better.
David - if you are still stating that a lot of gas is good, you cannot have actually met Pat!!!!
Wilf
Old 06-01-2002, 10:27 AM
SCOBRAC's Avatar
I have never seen a DP TP.. Sort of a mythical creature I suspect. Some parts guy it Detroit is probably using them as door stops in the Ford warehouse.. lol.. I think you really would be better off using what you have anyway.. How else are you going to get the 600hp you know you want..
Jeff.. You don't have a hair on your A.. if you don't put that flag signature back up.. :-)
michael
