Old 08-04-2002, 12:32 PM
Default Tremec_TKO into '69 Mach1, Advice
I have a '69 mach1 with rebuilt 390 and C-6. I found a tremec with lakewood bell and mcloued clutch and might be able to get a deal. iI was curious how big of a projhect this will be with motor in the car.
I will first of all need new pedals...
Thanks
RYan
Old 08-04-2002, 07:15 PM
Clois Harlan's Avatar
Default No big deal
I have done this switch on a 69 Mach I several years ago and it is really not much effort at all. Go to the salvage yard and pull off the brake and clutch pedals and all the hardware ie: clutch linkage, t/o brg lever etc. Of course you could put a hydraulic t/o bearing in place of the conventional one . You will need to pick up a pilot bearing ($15) and a good flywheel, clutch, PP. and throw out bearing. The trans mounts are the the same and the correct shifter hole (if I recall) is already marked by Ford and just needs to be cut out w/ a jig saw. Drive shaft length should be the same althought you probably have 308 gears in the rear end now. You may want to pick up another pumpkin w/ 325 or 350 gears.
Lets see about $300 for a good clutch and pressure plate assy, then about $200 for a flywheel, and you will probably spend about $20 at the salvage and then what ever you are going to pay for your trans and bell housing.
Find someone with a standard in there Torino, Mustang, Galaxie, or Fairlane that wants to put in an automatic and trade as much as you can. Good luck.
"Let's roll"
"Be part of Something Good
Old 08-07-2002, 10:47 AM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
Clois is right on--an easy swap. I put the TKO in my 66 with very little effort. One add on, if you're looking for a gearset, look at old service vans with 6 cyl engines--they normally have 9" rears with gearset 3.56 or better.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Rate This Thread:
