Old 09-11-2002, 06:43 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Default Lifting points
How complete do you have your FE when you install it?
Where do you pick from?I have a cast block w/aluminum heads and 2x4 tunnel wedge intake.
I had the engine down to short block when I removed it.I used a arm type crain from the front, that at its last hole it was 6 to 8 inches too short.What did you do?
Did you make or buy a special brackets ?
Mike H
