Old 10-04-2002, 08:19 AM
Default C6ME Block
Looking at a 428 Block with c6me code. The seller claims it's from a Police Interceptor or Ford Galaxie. Is this any other questions or markings I can find out about to see if it is a "true" PI block.
TIA.
Old 10-04-2002, 08:38 AM
computerworks's Avatar
Ford References say:
C6ME-A
1966
428
428-4v, Police Interceptor
Old 10-04-2002, 10:51 AM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Default pull the pan....
and see if it has the reinforced webbing,
then measure the rod bolts.
PI's have 13/32 diameter bolts.
What about the factory aluminum intake, is it on there ????
Good luck,
Bill Cook
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 10-04-2002, 11:04 AM
I will check it out.
Thanks.
Not sure what info I can get as it long distance and I will not be able to drive. Also, it's a standard bore block.
Are there any other code type indicators I can ask about?
Old 10-04-2002, 11:24 AM
That's the only ways I know of to check the block.
You can't trust the fifth digit (P) of the car, engines got changed all of the time.
Great to hear it's STD.
BC
