Old 05-09-2003, 06:47 PM
Cobra Make, Engine: ERA #664 finally done!
Default head bolt sequence
Anyone know the head bolt torque sequence for my 428(edelbrock heads)? I found the torque specs but can't find the sequence. Thanks for any help.
Old 05-09-2003, 07:05 PM
Hi Charlie
I would like that info too.........BTW can you list those torque specs for the edelbrock heads........I may have to recheck mine.
Is it mandatory after the break in and if so when?
Appreciate it
Tim
Old 05-12-2003, 04:13 AM
68gt500's Avatar
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Send a message via Yahoo to 68gt500
Same here, what is the recomended torque with the ARP head bolts?
What plugs are you using??
Old 05-12-2003, 05:03 AM
TC Cobra's Avatar
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Here's the sequence guys:
9 5 1 3 7
10 6 2 4 8
Not positive on the torque but in three steps, go 70, 80 & 90 ft-lbs. and then 100 on the longer bolts. I've also seen where some guys will go 100 on the short & 110 ft-lbs on the long.
Old 05-12-2003, 07:01 AM
Trans-Am Jim's Avatar
Send a message via ICQ to Trans-Am Jim
Edelbrock heads with ARP bolts and ARP moly lube - 85 ft.lbs.
Using 30 wt. oil instead of moly - 100-110 ft.lbs.
Jimbo
Old 01-16-2005, 02:35 PM
convincor's Avatar
Cobra Make, Engine: FFR 390 toploader IRS
Edelbrock say's 110lbs. on top row, 100lbs on the bottom with their bolts(ARP) and ARP lube.
ARP say's 85Lbs with their lube. 75lbs. if aluminum.
Which is right?????????
FFR MarkIII,FE,toploader,IRS,3.27,Vintage pin's SOLD!
68 F100 Custom Cab 418 cube FE/auto
99 SuperDuty Tuner/chipped/4" Banks TOTALED!!
02 Super Duty 7.3L
