| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
05-12-2003, 03:21 PM
fl
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Holley fuel pump?
Does the Holley(red?), with the engine off and the pump power on, run continuously, pressure comes up immediately but the pump never turns off? Is this normal?
gn
05-12-2003, 03:33 PM
CA
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
It shouldn't.. Hovever.. It may have positive residual pressure but that needs to be relieved (bled back to the tank) or you risk BBQ'd Cobra. If the pump is running all the time you need to run it throught the ignition switch or a circut that is off when the ignition is off.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
05-12-2003, 03:41 PM
fl
It is wired thru the ignition; the question is:
when the ign switch is on, fuel pump running but the engine not yet started. The pump comes on and never turns off, does the Holleys always run continously with power or do they turn off after reaching pressure?
gn
05-12-2003, 03:44 PM
Cal
They run as long as the ignition key is hot, they do not cycle on/off.
05-12-2003, 06:28 PM
Ont
Cobra Make, Engine: Classic Roadster with 427 center oiler
I have an electric Carter pump and it runs all the time the ignition is on.
Paul
05-13-2003, 06:06 PM
fl
thanks guys!
My Holley sound like it's grinding up rocks and I was a little concerned; although can't hear it over the stoker
gn
05-13-2003, 06:46 PM
TX
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Grinding up rocks..........
Very accurate description!
Bud
05-13-2003, 07:31 PM
NH
I have the Holley Blue and it is very noisy. Yes, it is on all the time the ign is on.
Mike
05-14-2003, 01:13 PM
fl
One more question.
Do you set the 6 psi on the Holley reg. with the engine running or with the engine off and the pump pressurizing the carb?
gn
05-14-2003, 02:24 PM
NV
Cobra Make, Engine: ERA 427 SO
Niles, set the pressure with the motor running (but it shouldn't make much difference).
Another safety suggestion, you might want to consider wiring an oil pressure warning light switch into the switched power circuit on the fuel pump, with a manual override. That way, you can get in the car, prime the carburetor with the override and start right up, but if the motor ever quits (accident, etc.), the fuel pump won't keep pumping fuel, possibly through a torn fuel line.
Ken
