February 2026
Old 09-26-2003, 01:56 PM
Cobra Make, Engine: ERA #059,428
Default Tell The Different In Fe
HOW DO I TELL THE DIFFERENTS IN FE ENGINES I FIND IN THE JUNK YARD ? THANKS TMAN0950
Old 09-26-2003, 06:21 PM
FFR428's Avatar
Well if you can find the casting numbers and date codes that is a good start. If you can remove the head to measure the bore this will give you some clue but with overbore might make it difficult. Also the year and vehicle it's in is a help also. If the engine is out of the car take the oil pan off to get numbers and markings off the crank and rods also. These are a good start. Glenn.
Old 09-26-2003, 10:36 PM
some reading material for your weekend...
FE Block Info
Casting Number Reference
Read pages 29 thru 41
George
Old 09-28-2003, 08:52 AM
THANKS FOR ALL THE FE INFO, I HAVE FOUND A 390 IN A JUNK YARD AND I AM GOING TO PULL IT TODAY. THEN IF I DON'T FIND ANYTHING BIGGER BEFORE I AM READY I WILL USE IT. THANKS AGAIN. TMAN0950
