Old 09-27-2003, 08:31 PM
Send a message via ICQ to pro-st-fairlane
Default clearance issue?
i have 12:1 trw pistons with a crane solid lifter cam with a .595 lift in a 390 with a set of 390 heads that have had the valves takin out to 428 cj size valves does anyone know if with running a 1u crank because of the bigger stroke am i going to have any clearance issues?
Old 09-27-2003, 08:59 PM
Cobra Make, Engine: contemporary cobra
you should be fine but its good to check in case the block has been milled a few times .
Old 09-28-2003, 12:47 PM
the block has not been milled at all
does anyone know if by running the bigger stroke 1u crank does it make the compression go up and does anyone know by how much?
Old 09-28-2003, 09:26 PM
the only way to know is to measure deck higth remember that all rods will stretch .030 under load .
