Old 10-03-2003, 11:21 AM
Default Erson Roller Rockers for Edelbrock Heads
When I designed the Erson roller rockers, the Edelbrock FE heads were just getting started so I designed the rockers to fit standard 390/428 heads. They can be used on Edelbrock and 427 heads but they must be taken apart and shims moved around in order to match the valve spacing of the Edelbrock/427 heads.
Because so many people are now using Erson rockers on Edelbrock heads, we have released a new part number with the rockers already adjusted for Edelbrock/427 heads:
Rockers for Edelbrock/427 heads: E918503
Rockers for standard 390/428 type heads: E918502
Old 04-15-2007, 01:30 PM
82ACAUTOCRAFT's Avatar
Cobra Make, Engine: AC Frua, FE Side Oiler
How good are the Ersons?, I use original 427 and 428 rockers in my cars!
Old 04-15-2007, 01:48 PM
The Ersons are probably the best....next to T&D's.
Old 04-15-2007, 01:51 PM
Jamo's Avatar
Super Moderator
T&Ds...what I have. Muy goodo IMO.
Jamo
Old 04-15-2007, 01:56 PM
What are T&Ds'?
Old 04-15-2007, 02:06 PM
It's a brand of roller rockers. Instead of using the regular studs that usually hold the shafts down, they use the head fasteners. Very high quality and very stout.
The Ersons are rated for spring pressures of 800 lbs.
If you ever plan to use a solid roller cam with spring pressures over 500 lbs or so, you'll see how factory shafts and hardware hold up.
Old 04-15-2007, 02:08 PM
To they fid in the stock valve covers? and what does T&D stand for?
Old 04-15-2007, 02:10 PM
They will fit in most valve covers. I guess it depends on what you have. I have a buddy with a set and they fit under the chrome pentroof valve covers.
To be honest, I don't know what T&D stands for.
http://www.clubcobra.com/photopost/s...0&ppuser=12166
Old 04-15-2007, 02:13 PM
Awsome, great, thanks!
Old 04-15-2007, 03:03 PM
JLC800's Avatar
Cobra Make, Engine: PPMC 427 SO
I have over 8000 miles on mine and just one adjustment around 500 miles.
They are excellent rockers.
Jim Cinalli
Old 04-15-2007, 04:33 PM
jwoodard's Avatar
Thumbs up
T&D Machine Products is the name of the company. Here's a link to their WEB site: http://www.tdmach.com/
What exactly T&D stands for is a good question. Probably the initials for the pricipals in the company. Larry Tores is the name of the President so maybe the T stands for Tores.
Jim Woodard
Old 04-15-2007, 06:17 PM
jdog's Avatar
Cobra Make, Engine: Shelby CSX4795 (Sold)
Thumbs up Look Good!
Ersons run well and they look good to!
jdog
"If you can't run with the BIG DOGS, stay under the porch!"
Old 04-16-2007, 01:53 PM
Cobra Make, Engine: Building ERA #749 427 Cobra
RobbMc
When are these assemblies going to be available? Both Jegs and Summit say "no such thing, they most likely aren't released yet".
Old 04-16-2007, 02:11 PM
xracerbob's Avatar
Cobra Make, Engine: ERA 758 KC Pond 482
Keith Craft and Flatlander have them available among others I'm sure. They've been out for a while. I think they're around $650 a set.
Bob
Old 04-16-2007, 03:39 PM
RodKnock's Avatar
I believe the T&D's are about $1,300.
Old 04-16-2007, 03:42 PM
RodKnock's Avatar
I should also say that the Viper owners swear by them (T&D's).
Old 04-16-2007, 04:56 PM
Ibr8k4vetts's Avatar
There is one more reason to run Ersons
Mike Z
Old 04-19-2007, 04:00 AM
Default Rockers
T&D are great and need about $300.00 of head work to machine the mounting pads flat for the assembly. Jesel also makes a great setup about the same price. Which Ersons fit the Shebly heads? What number? Rick L
Old 04-19-2007, 05:01 AM
Clois Harlan's Avatar
I have had mine (Sig Erson) for about 5 years and they have been a great investment. Easy to adjust and reliable. Believe it or not they actually cooled my oil by about 10 degrees. But, that was my old 428 engine. The 427 has the opposite problem (I have trouble getting my oil hot enough, 220 or 230 deg is what I would like to see).
"Let's roll"
"Be part of Something Good
Old 04-19-2007, 06:32 AM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Clois,
I consider that hot for oil, I normally like to see the oil temp around 190-200. I also have the same problem. Takes forever to get the oil temp up. And that is in Fresno CA.
Morgan LeBlanc
Fresno CA
