  #41 (permalink)
Old 10-29-2003, 07:51 PM
I feel lucky today and am going to give this another shot. Steve
  #42 (permalink)
Old 10-29-2003, 09:23 PM
Eljaro's Avatar
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
My 427 C/O : simple and uncluttered
  #43 (permalink)
Old 10-29-2003, 09:25 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
m
  #44 (permalink)
Old 11-05-2003, 09:44 PM
sorry, i didn't know at the time of painting, cobra blocks were 'sposed to be black....
  #45 (permalink)
Old 11-05-2003, 11:36 PM
Cobra Make, Engine: kmp927
ok its my dads motor i didn't have the cash for the polished parts!
Aeon
  #46 (permalink)
Old 11-06-2003, 04:44 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Another 427 side oiler in an ERA.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
  #47 (permalink)
Old 11-06-2003, 05:44 AM
chuckmynatt's Avatar
Cobra Make, Engine: BDR / 347 stroker
Here's mine:
347 Stroker, Holley 650 DP, Comp Cams 284 Duration HR.
  #48 (permalink)
Old 11-06-2003, 06:33 AM
sierramadre45's Avatar
Cobra Make, Engine: Superformance 1710, Sunset Red/Titanium Stripe, 428 FE with dual quads
  #49 (permalink)
Old 11-06-2003, 09:21 AM
Cobra Make, Engine: dual paxton 427 Cam Am Cobra
427 center oiler 5 over, with rollar rockers ,shelby heads, eagle rods, dynoed at 639HP and 605ft/lb
  #50 (permalink)
Old 11-06-2003, 04:33 PM
Tom, Speed 220,
Very pretty compartment, however I noticed you have early-style ERA brass radiator.If you care, you can shave 15 lbs. off the nose and gain substantially better cooling by installing ERA's aluminum unit which is now standard. I swapped into my early chasis and have been very happy.You also won't believe how easy to do one-man rad. removals when necessary.Hardest part of the job is draining the system, and can be complete on a full Saturday.
Respectfully,
Chas.
  #51 (permalink)
Old 11-06-2003, 06:03 PM
Hi Chas.
Thanks for the recommendation. I've been thinking about doing just what you suggest. I have a question, though: Is the same mounting hardware used so it's a direct R&R, or do I need to purchase any other items other than the radiator?
Tom
  #52 (permalink)
Old 11-07-2003, 01:56 PM
Tom 220,
Yes and no. Radiator comes with lower chassis attach pan, just like your present one only nice shiney [and LIGHT] aluminum.Also has needed cotters for upper[1]and lower[2] fastening.Whats needed is the upper rad. to body panel, which on your car is held to body by 5 sheetmetal screws directly into the fiberglass. Here,s what I did. When the main components arrived from ERA, I made a pattern of the upper attachment [which has slightly different angles than the present steel piece],and sent it to Teddy at ERA, who fabricated a perfect piece in alum. Or if you're more talented than me you could do this yourself. While awaiting the upper piece, I fabbed a "nut bar", a piece of 1/8 steel with 1/4-20 nuts welded to the back, the width of the body front hood line. I slightly opened the 5 holes in the body,siliconed the steel bar on the forward edge [under nose] and then through- bolted 1/4-20 button head allens into the piece Ted made. Easily removable for cleaning or polihing and the fasteners are always nice and tight. My fan mount frame fit with no trouble. Future rad. removals will be system drain, upper and lower hoses, and three cotters. A real timesaver. Hope you try it. The whole deal was something over $400, but I don't remember total. Good luck as it's worth doing.
Chas.
  #53 (permalink)
Old 11-07-2003, 02:11 PM
bnewell's Avatar
Cobra Make, Engine: Kirkham 427FE (sold & missed)
sierramadre45 ~ that is sweeeet!!!!
Brian
  #54 (permalink)
Old 11-07-2003, 05:27 PM
Chas.
Thanks for your response. Sounds like the fabrication and installation are relatively simple compared to some other projects I've been involved in. But I'd better started now budgeting for the radiatior and related pieces.
Thanks again.
Tom
  #55 (permalink)
Old 11-07-2003, 06:57 PM
Brian,
Thanks. I was extremely happy with the way it turned out. The builder/installer was John Vermeersch of Total Peformance in suburban Detroit. Within Ford Motor Company, John and his team are regarded as the foremost FE engine experts in the USA. They made me a believer and are great guys to work with too. I highly reccomend them for anyone considering an FE.
  #56 (permalink)
Old 11-07-2003, 07:50 PM
bmalone's Avatar
Bill Malone
Gashole
CSX4786
  #57 (permalink)
Old 11-09-2003, 09:24 PM
surfer44's Avatar
Cobra Make, Engine: Hi-Tech Serial 0122 66 428, Tremec 3550. AMP 9" Ford IRS
Send a message via AIM to surfer44
Nothing exotic YET! 1966 428 Soon to be fired up!!!
Thanks,
Neil Brady
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out and loudly proclaiming:
"WOW, what a ride!!!"
  #58 (permalink)
Old 11-09-2003, 11:33 PM
Bill E's Avatar
This is an all aluminum 351 stroked to 416 the block is from R.D.I It is a dry sump. The heads are Trick flow that spent 8 months at Air research 1100 CFM Demon carb lots of titanium goody inside. The engine weigh less than the trans and bell Housing. Should be will over 600 HP the hole car is only 1835Labs.
Bill Emerson
  #59 (permalink)
Old 01-12-2004, 04:15 PM
Southern Automotive 428 Cobrajet
_________
JC
  #60 (permalink)
Old 01-12-2004, 06:07 PM
zimmy's Avatar
Cobra Make, Engine: Contemporary, 427 FE Center Oiler w/ 48 IDA Webers
Send a message via AIM to zimmy
427 Center Oiler, stroked to 454 w/ Scat 428 crank, Eagle H rods, JE pistons, Crane solid lifter cam, Erson roller rockers, Edelbrock heads, 48 IDA Webers.
Engine dyno results: 527 HP, 575 lb-ft of torque!
Rate This Thread:
