November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-05-2004, 02:45 PM
MIKE SCHULZ's Avatar
Cobra Make, Engine: Contemporary 427 CCX 3627 ,TKO 600 RR,TWM 58mm DFI
Default Head Gaskets..Copper vs Composite
Gentlemen; I need some advice on the best head gaskets to use on an Iron 427 block and Edelbrock alum heads.I like the idea of using Copper gaskets but I have heard of "Electrolisis" happening, and that leads to corrosion issues.What do you guys think??. Also I would like to aquire a serpintine pulley setup for my Engine.....Anyone you know make em??.Thanks for your time....Mike Schulz B.C Canada.
Old 01-05-2004, 02:53 PM
Mr.Fixit's Avatar
who runs copper head gaskets nowadays?
Old 01-05-2004, 03:09 PM
750hp's Avatar
Mike, copper gaskets are great for high maintenance drag racing engines, but I don't think they have a place on the street. As for brand-specific 427 gaskets, I couldn't help you there...
Craig
Old 01-05-2004, 03:21 PM
I used them on my BB Chebby and had no problems whatsoever,I like to hear of other Enthusiasts experiences so I may "build it right" the first time. After all...Knowlege is Power!!
Old 01-06-2004, 01:28 PM
The Felpro #1020 seems to be the gasket of choice for most FE street cars. I've used this gasket many times with no problems.
The only problem I have had running copper gaskets on the street is occasionally I've had minor external coolant seepage. Not bad, and it would come and go.
--Mike
They bend 'em, we mend 'em.
