Old 01-28-2004, 04:08 PM
FUNFER2's Avatar
Default NEED- FE bolt specs. (mains, rods, ect.)
Hey guys, do any of you have the bolt torque specs. for FE's (428) that you could send me or post it so I can copy them ?
I'll be assembling this Fri. Sure would help !
Thanks,
Kevin
Regards,
Kevin
Old 01-28-2004, 05:06 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Here's a page.
http://www.cobra-replica.co.uk/html/cobra_53.shtml
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 01-28-2004, 05:47 PM
ted ted is offline
Default What out for those posted torque specs.
I looked at that site (http://www.cobra-replica.co.uk/html/cobra_53.shtml) that shows the torque specs for the various Ford engines and the head bolt torque specs for the 429/460 and the Fe's would at first appear to be transposed (backwards). Upon closer examination, the specs are correct but I just looked at it wrong initially due to the engine family listings being closer to the specs (although below) instead of following the torque specs below the engine postings.
As a reitteration, the head bolt torque for the Fe needs to be 105 lbs., not 140 lbs. Likewise for the 385 series, it needs to be 130-140 lbs., not the listed 105 lbs.
I'd have deleted this post but it wouldn't let me so I just rambled on in the edit mode in order to make some sense out what I originally said.
Ted E.
Old 02-01-2004, 01:12 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Are you reusing OEM or new stuff, ARP studs? I found that the ARP stuff reccamends their lube and a resulting lower touque #. It really makes a difference..On alluminum heads you can start bending things and pulling threads.
The problem with Original 427 was OEM rod bolts ARP has a cure for that.Problem is they measure the stretch I had a engine builder do it since he had the stretch gauge and knew what he was doing and so forth.
Mike H
Old 02-08-2004, 08:36 AM
FUNFER2's Avatar
Thanks guys, I appreciate your time.
Regards,
Kevin
