Old 03-15-2004, 11:44 AM
RedCSX1's Avatar
Question Mounting oil dipstick on Aviad pan.
Trying to figure out how to mount the dip stick supplied by Avaid to the pan. Tube seems very long do I need to cut this down?Can any one supply me with a close up picture or diagram? Also I think the tube attaches to the front of the head correct?
thanks,
Morgan
Morgan LeBlanc
Fresno CA
Old 03-15-2004, 11:55 AM
Jamo's Avatar
Super Moderator
Give me a moment...
This shows you what it ends up looking like. You can always come over to see what it looks like in person.
Jamo
Old 03-15-2004, 12:58 PM
For the actual connection to the pan, did your dipstick come with a brass fitting that has two open ends to it, mabe about 1.5 inches long? Each end for this fitting has a rubber ring inside it--one to slip onto the pan bung, the other for the dipstick tube to slip in. That fitting then has two "nutlike" collars that tighten those rings onto each for a tight seal.
Old 03-15-2004, 01:26 PM
Mine is similar to JAMO's above. My tube is attached to the lower water pump bolt and is hidden behind the expansion tank. It sounds like your talking about the driver's side of the engine since most heads don't have provision's for bolts on the passenger side front.
Old 03-15-2004, 02:51 PM
RedCSX1's Avatar
Default thanks Jamo and Cracker
Jamo, I think I might take you up on that visit soon. The dip stick just loked hight to me when i put it in position.
Cracker, thank you as well. On the pass side of the elebrock heads i think there is a threaded hole. The water pump bolt, very helpful information. My dealer told me not to use the brass fitting. He said to use a short piece of hose in its place, so its flexible enough to move.
Morgan
Morgan LeBlanc
Fresno CA
Old 03-15-2004, 04:18 PM
Jamo's Avatar
Super Moderator
Morgan
Let me know...given our weather, I can easily be talked into bring the beast to work. There's some moron with a big ol POS BMW pretend cafe racer that parks in our parking lot that I need to show up on occasion.
Jamo
Old 03-16-2004, 07:36 AM
Cobra Make, Engine: Kirkham, Pond Aluminum 482FE
Red,
I did mine differently - mounted off of block instead of water pump. Here it is:
Old 03-16-2004, 08:02 AM
RedCSX1's Avatar
Default Perfect Shot, thank you
Just what I was looking for. I wa also wondering what the other port was for. It looks like you just capped it off?
thanks again,
Morgan
Morgan LeBlanc
Fresno CA
Old 03-16-2004, 08:25 AM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
The other port is for any excess oil in the puke tank to drain back to the pan.
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 03-16-2004, 08:47 AM
DougD's Avatar
Default dip stick
I didn't receive one of these with my pan. Where can I buy one?
Old 03-16-2004, 09:32 AM
Doug and Morgan,
The dipstick and the cap are available from Gessford for about $30 and $18, respectively. That little bracket off of my block is just a piece of flat stock with a couple holes drilled in it (nothing fancy).
Joe
Old 03-16-2004, 01:52 PM
DougD's Avatar
Default thanks
Joe
Thanks for the reply. I'll give George a call.
Doug
Old 03-16-2004, 10:07 PM
Hi Morgan....
These are some other images that might be of help...
George
Old 03-16-2004, 11:32 PM
Jamo's Avatar
Super Moderator
Thumbs up Way to go, Jorge!
Dipstick art.
Jamo
Old 03-17-2004, 07:24 AM
RedCSX1's Avatar
Thumbs up George Thank you
Great detail shots of some awsome FE iron. Since I don't plan to run a oil puke tank I will have to find something to use to cap off the oil return port.
thanks again,
Morgan
Morgan LeBlanc
Fresno CA
