Old 06-04-2004, 08:34 AM
Cobra Make, Engine: ERA #059,428
Default Oil Temp Sender ?
WHERE DO I INSTALL THE OIL TEMP SENDING UNIT? THANKS
Old 06-04-2004, 08:46 AM
Clois Harlan's Avatar
If you are running an after market pan there is a fitting that works real well. If you are running stock oil filter and pan you may want to put a tee fitting off your oil pressure sending unit (located near your oil filter) . The best place I think would be somewhere in your return oil cooler line if you have one.
Clois
"Let's roll"
"Be part of Something Good
Old 06-04-2004, 08:48 AM
Cobra Make, Engine: FFR 1137 EFI 347
You've got several options:
1. Depending on the pan, if stock there are adapters for the low oil sender on front right.
2. Into remote filter adapter
3. Buy an adapter to go in-line with the remote filter.
4. If after-market pan, punch a hole. Mine's(Gordon's pan) in left side.
Mike Foss
Old 06-04-2004, 09:53 AM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
I have mine in a tee fitting at the oil pressure sending unit. It is useless there. Since no oil flows through that fitting the temp on the guage is always very low. If you can't find another location such as the pan or oil cooler line don't waste your time on the tee idea. IMHO
Old 06-04-2004, 11:55 AM
DonC's Avatar
Wherever you install it make sure that the location will allow the senso to be submerged in the oil as most are "wet bulb" types that won't read correctly unless it's in the fluid.
DonC
Old 06-04-2004, 02:54 PM
Bob In Ct's Avatar
Do not put it "after" the oil cooler. If you can't measure the oil temperature in the crankcase it should be measured as soon as it comes out of the crankcase (before hoses, cooler and filter), oil pressure should be measured just before it enters the engines (after hoses, cooler and filter).
Old 06-04-2004, 03:02 PM
I have the same question.
I'm running a 351 W and there is a threaded plug on the side of the block under the headers. Is this where you are supposed to put the temp and pressure units?
Roger
Old 06-04-2004, 05:00 PM
Tony Radford's Avatar
When I bought my car, the sending unit was in the auxillary dip stick hole in my Canton pan. It never worked for two years. I eventually had it moved to my oil filter adapter and it works great. I believe the oil adapter is the best place.
