Old 07-03-2004, 02:44 PM
R U YELLA's Avatar
Ed Digges
Cobra Make, Engine: Kirkham #328 w/ 390FE
Default What is this FE?
Is this a 390 or 391? Block #'s are D4TE (1974 Truck Engine) with a mirrored 105 and a 13 underneath that. Tag on the block states it is a remanufactured block with a bore of 4.0. You can see some pics at: http://www.capitalareacobraclub.com/...view_album.php
If I can get this engine for free, would it be worth rebuilding?
Catch ya later
Ed
Old 07-03-2004, 05:47 PM
ENTDOC's Avatar
390 should have 4.05 bore.There was a D4TE-AC code on the 390 in 1974 however.I suspect it is an FT series 391 and if it is I would avoid it.You would still end up putting more money in it than it is worth and 390's are cheap. chuck
Old 07-03-2004, 10:17 PM
It might have a steel crank. Grab it and look it in the mouth later.
All my ex's live in Texas
Old 07-04-2004, 09:02 AM
HEY, ED - - -
YOU SHOULD GRACIOUSLY ACCEPT ANYTHING THAT YOU CAN GET FOR FREE.
CAN I INTRODUCE YOU TO MY EX-WIFE ?????
ALL SERIOUSNESS ASIDE - - I AGREE WITH STEVE.
Y'ALL HAVE A REALLY GREAT DAY.
BLACKJACK
Old 07-04-2004, 08:02 PM
jschiller's Avatar
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
Genuine FT 391's are highly prized. Because its a truck block, the bore will support overboring to 428 size. Maybe even 427 size depending on a good sonic test. Look for a larger than normal distributer hole in the block. A FT dizzy has a larger diameter shaft but a reducer will allow a standard FE dizzy to be used.
