Old 07-13-2004, 01:56 PM
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
Default Pump Gas and 11:1
how many are using 11:1 compression and pump gas ? do you find it is a tunable combinatin ?thanks,Tim
Tk
"this whole Adult thing just isnt working for me "
Old 07-13-2004, 03:34 PM
Gasman's Avatar
Cobra Make, Engine: Unique, S.A. 427 center oiler
http://www.vpracingfuels.com/vp_01_f...B7C86B4900C50C
Read the specs on VP Performance leaded product.
Steve
Old 07-13-2004, 03:52 PM
Hey Tim,
Not in a Cobra, but my '73 Corvette has a 454 running 10.8:1 with aluminum heads. It runs on premium with no problems at all. In fact, it runs well enough that I'm often tempted to put in some regular just to see what happens.
I think that as long as you're running aluminum heads, 11:1 is doable in any configuration so long as your cam choice matches the C/R.
Tom
Old 07-15-2004, 11:34 AM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Alluminum heads give at least .5 break.( you didn't say. I'm at 11.5 -1.I have alluminum heads run pump gas but use an additive ment for motorcicyles. It came reccamended with the car from the original engine builder.I had a cam go flat and had the engine torn down ,no damage noticed. I haven't bought any racing gas yet. But plan on splashing some in the tank in the future.
Mike H
Old 07-19-2004, 02:56 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
No. Just say no enless you ave access to 95 octane or better. 98 would be even better. We have 91 in California and life is pretty tough.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 07-19-2004, 03:09 PM
rdorman's Avatar
Renegade Nuns on Wheels
Waiting for the engine builders...............
Setup correctly, I think you can. Premium is 93 octane here with some 94 even available. Aluminum heads, quench chambers, cam, ignition timing, pistons would all have to be right on though. Maybe even coat the piston tops and chambers. Old iron heads, I think that is a big fat forget about it!
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 07-19-2004, 05:02 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Yes you can do it with aluminum heads and the right cam. Would need some fine tuning to keep it from knocking when hot. With a good cooling system you should be able to do it. I have built them up to 12 to one on a 427 with iron heads but they were new Medium riser heads that we polished as well as the piston tops. The trick is not giving the pistons or heads any place to build up a hot spot that will start the knock.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
