Old 08-21-2006, 02:39 PM
luke-44's Avatar
Default FE Waterpump Gasket Sizes?
I went to change out the gasket on the back of the water pump - the one that has 6 bolts - the plate holes are 5.25" center to center across, my gasket is a perfect 9/10 scale - 4.75".
Plus, my gasket seems quite a bit thinner..
Is there more than 1 size? How do you specify (large/small?). Or, did I somehow get a gasket for something else??
Where is the best place to buy this?
Thanks,
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
Old 08-23-2006, 12:08 AM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Oh, the work I go through for people on this forum...I've got 5 of the 5 1/4" gaskets (never install them). I emailed you one...let me know if you get it. I checked the listings, and the same gasket fits all years. I even checked one against my '68 casting (larger internal bearing starting in ''68), and it matches. I don't know where you got the oddball nor what it fits. If you've got gasket paper, go to work, as thickness won't matter on this, unless it's really thick.
Good Luck,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
Old 08-24-2006, 05:44 PM
luke-44's Avatar
Ummmm....appologies from my parts department guy...I'm now told he gave me a Buick 3.8 waterpump gasket.
So next time someone asks you at a cocktail party "do you know what waterpump gasket is an exact 9/10 replica of a Ford FE's"?... You'll know the answer...
Bruce
