Old 08-25-2004, 03:53 PM
Default 428 FE oiling mods for racing
Need to know what needs to be modified in the oiling system of a 428 FE block. Also, any required reading that I should know about.
Old 08-25-2004, 04:03 PM
427 S/O's Avatar
Get Steve Christ 'How to rebuild your big block ford' or, go to 'Fordmuscle.com and search their archives.
Perry
Old 08-25-2004, 06:03 PM
FFR428's Avatar
Also check the archives at www.fordfe.com G.
Old 08-29-2004, 03:27 PM
FE Stroker Do your self a favor and have a machinist do the important modes to the block. You can do the oil limiters to the heads but drilling out the passages go to a machinist. Find an FE machinist on the column to your left. It's worth it in the long run. my 2 cents Rick Lake
Old 08-30-2004, 12:39 PM
Rick Lake---Thanks for the advice, however, I am a machinist & a tool & die maker---just need to know what to do. Thanks, Bill
Old 08-30-2004, 03:56 PM
FE stroker Bill there are 2 articles on what to do with the FE oiling system. Do you have a fax machine? I didnot know your profession. It's best to go to the guy with the right tools and smarts to do the job right the first time. Rick Lake
Old 08-31-2004, 03:03 PM
Rick---I'm kind'a in an area where FE' s aren't worked on much, so getting any info is hard to come by. I had talked to a couple of Super Stock racers--and they gave me a # to call in MN., but the shop never called back. That's when I thought I'd give this forum a shot. You can fax any info to (920) 648-4579---that # is to a friends repair shop.
Thanks, Bill
Old 09-02-2004, 03:25 AM
Fe stroker Bill I am busy till after this week end. I have to find the rticles in my mag collection. It's basic work. 1/2" supply of oil from the pad mount to the center of the block. Align oil holes with the bearing holes on the mains. 100 lbs spring in the oil pump for better pressure. This one is questionable because of the wear on the distrubutor gear. You may want to go dry sump oiling for racing. Motor # 2 is going with an Aviavid system. They sell dry and wet external systems. I'm going dry sump. oil limiter in the heads. size is from .090" to .055". I have .070" in my heads and plenty of oil up stairs. Got to go Rick Lake
Old 09-02-2004, 12:08 PM
Thanks, Rick
Old 09-05-2004, 04:12 PM
luke-44's Avatar
Bill - I am posting the mods I did to my Edelbrock heads in a separate posting here in the FE section. Hope this helps,
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
Old 09-05-2004, 05:45 PM
DuckRyder's Avatar
Cobra Make, Engine: I Wish, Just an old truck with an FE
Send a message via AIM to DuckRyder
Try these two links:
http://www.gessford.com/projects/feoiling.htm
http://www.doveengineparts.com/image...oTheFordFE.htm
Hope this helps.
Robert
1972 Ford F100 Ranger XLT
1975 Porsche 914/4 2.0
2002 Honda RC51
323i.net
RangerXLT.com
The Forums@323i.net
