November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-17-2004, 09:49 AM
Cobra Make, Engine: CSX4000, 427
Default Which head gasket for FE427 ?
I'm in the process of rebuilding my 427, and I'm wondering if the head gasket supplied in my FELPRO kit , gasket #8554PT would be OK to use, or should I buy the FELPRO #1020.
The 8554PT gasket looks to coated with blue color ? teflon, and has metal rim around each combustion chamber.
I think it would be OK to use, but I'd hate to use it, then have troubles with it at a later time, requiring me to replace them.
Thanks.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 10-17-2004, 09:59 AM
Anthony What's up 1020 Felpro with Hightack is what I used. The 1020 has be listed for the 427 bore for 20 years if not more. What was on the engine before? ASk your builder what he used. I would use the Hi tack with Alum heads and iron block because of the expanding rate of the different metals. Send me an email with your number I can call. What did you find on the motor. Make sure you put the gaskets on the right way. Rick Lake
Old 10-17-2004, 02:28 PM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Anthony,
The FELpro 1020 is tops for 390-427 eith iron/iron or iron/alum. Like Rick noted 20 plus years, not one blown in our camp.
grumpy
Old 10-17-2004, 06:05 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
The FEL-1020 is the 427 unit. I had a Felpro for a 390 and it wouldn't quite clear the chamfered edge for the 427 (tunnel port) intake valves.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
