Old 02-07-2005, 03:57 PM
Default rebuilding a 390
where is the best place to purchase a master rebuild kit for this engine ill need pistons rings bearings etc.mike
Old 02-07-2005, 05:24 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Check out PAW.
www.pawengineparts.com and order a catalog.
They have all sorts of FE rebuild sets in different stages.
Dave
55 mph is unsafe at any speed. Huh?
Old 02-07-2005, 06:45 PM
SCOBRAC's Avatar
What Dave said. Jegs and Summit are good too
michael
Old 02-07-2005, 06:57 PM
Whats the max over bore for a 390 block?
Adrian
Old 02-07-2005, 07:19 PM
elgecko's Avatar
.060" max, even then you should sonic test the wall thickness.
I went with .040" with my 390.
Dave
Old 02-15-2005, 03:14 AM
MetaJacko's Avatar
Cobra Make, Engine: Metaline 1969 Ford 390 bored to 402ci
Dave
Depends on the age of the block. IE early 60s can't take it but later ones can. Mine is at +60. Obviously only do enough to clean it as +60 pistons are harder to get hold of than +40.
Remember, +80 is actually a 406 bore (Although I've not seen anyone offereing 406 pistons)
Paul
