Old 02-19-2005, 03:45 AM
MetaJacko's Avatar
Cobra Make, Engine: Metaline 1969 Ford 390 bored to 402ci
Originally posted by FFR428
Paul, if the block has vertical ribs on the outside good chance it's a 70's era service block. Check the date code. The first number will have two dots underneath it for a 70's block also.
Hi
I've found the date code of what looks like 9L26 with two dots under the 9 so is this supposed to be cast
26th November 1979 ?
Did they even make FEs then?
It is and has always been solid lifter since the oil holes are not drilled.
According to that I have a 390 solid lifter cast in 1979 does that make sense
Paul
Rate This Thread:
