Old 02-18-2005, 04:31 PM
Cobra Make, Engine: don't have one
Question FE Cylinder Heads & Blocks
I've located 2 FE engines.
The 1st one has valve covers with "THUNDERBIRD"
embossed on them.
The casting number on the heads is: C4AE 0060
Casting number on block 04A DIF
The 2nd engine.
Head: C8AE-H
Casting # on block 59 352
Also 25A DIF
I believe these are both 390's
Would anyone happen to know of a definitive way of determining
the displacement thru the casting numbers?
Old 02-18-2005, 10:59 PM
Check the right side of the block toward the front for a different casting no., something like C6ME.
Old 02-18-2005, 11:06 PM
Ibr8k4vetts's Avatar
The only definitive way is too pull the head!
Mike Z
Old 02-18-2005, 11:22 PM
I can't tell you what blocks you have without a different casting number. There should be more numbers on the blocks. The numbers should be similar to the head casting numbers. Example: C8AE-A is a 68-76 390 block.
As for the heads:
C4AE = 64-65 352,390
C8AE-H = 68 std. 390 w/AIR
I got that info from "How to Rebuild Your Big-Block Ford" by Steve Christ.
Old 02-19-2005, 05:06 AM
FFR428's Avatar
The one with the thunderbird valve covers might be an early block if it has 2 bolt motor mounts vs the later four bolt if original. Check for the date code on the blocks. It's below the oil filter adapter mounting pad and is a number/letter/number(s) sequence. As mentioned look for the casting numbers on the blocks. Fords early blocks (60-64) were pretty good for casting numbers. They did not repeat on different blocks like some of the later numbers.
Old 02-19-2005, 10:15 AM
Thanks all for your help
