| 29 |
04-22-2005, 01:50 PM
VT
427 Expansion Tank
I'm going crazy trying to find an expansion tank for my 427 center oiler. The old one has pin holes in the brass that won't hold up to a solder job. I'm dumbfounded that these things are so expensive. Gessford wants $415 and Finish line wants $350 but then you have to solder the whole thing together. The soldering thing makes sense to allow for different applications but the price is nuts. Does anyone have
any other source for one of these? I didn't pay that much for my new Canton oil pan, windage tray and pick up combined!
(and no..... I don't serve cheese with my whine!)
Tim
04-22-2005, 01:58 PM
Cobra Make, Engine: NAF 427
Tim. These expansion tanks are always on e-Bay. I've bought 2 at reasonable prices ($75.00 and $85.00) and both were in excellent condition and tested OK at a rad shop. I'm keeping one as a spare in case of pin holes.
Greg
04-22-2005, 02:30 PM
I have one for sale.
Tim,
I have one for you. Was completely redone by the radiator shop. I did have the outlet moved over to the left side for the shelby. I can send you a picture if you like. Or you can just go to my Picture Page and see the one titled "Day at the Dyno" I will take $85.00 for it. I have more than that in it.
Morgan
Morgan LeBlanc
Fresno CA
04-22-2005, 06:20 PM
VT
Morgan
To orient the outlet back to the right side. I would only have to solder the mounting bracket on the opposite side and turn the thermostat pipe 180 degrees. Is that right? If so, I'm interested.
Tim
04-23-2005, 05:56 AM
Tim...the tanks most of us have are complete and ready to install...no additional soldering......for one that you put together they run 285$
George
04-23-2005, 06:34 AM
Tim,
It's a litte more involved than that, because you also have to turn the neck. But anything is possible at a radiator shop. Let me do some checking with friends I might be able to locate in with the outlet already on the right side. Send me a private e-mail with your phone number.
Morgan
Morgan LeBlanc
Fresno CA
04-23-2005, 12:39 PM
Tim,
I spoke witha friend (a real FE guy)who has one with the orientation that you need. Just have it boiled out and pressure test it. Wants 100.00 Let me know what you want to do.
Morgan
Morgan LeBlanc
Fresno CA
04-23-2005, 02:33 PM
OR
Does anyone have one that would fit a small block- 351W? With the orientation of the hose connection toward the drivers side?
04-23-2005, 03:17 PM
VT
Thanks everyone for the help. I found one on e-bay last night and managed to sneak in the last bid. It's the correct orientation so it looks like I'm all set.
Thanks again
Tim
04-23-2005, 03:26 PM
Ok then, looks like I'm buying Morgans. It has the right oreintation for my FE with no mods required, just bolt on.
04-23-2005, 03:32 PM
tim, contact me if you still need one
I don't want you to miss understand Ernie's note I still as I stated have a friend that has one that will work for you.
Morgan
Morgan LeBlanc
Fresno CA
04-23-2005, 03:36 PM
Good point Morgan, I'm buying tank #1, similiar to as pictured in Morgans gallery (I HOPE thats the one!).
