Old 04-27-2005, 07:02 AM
Default 2X4 air cleaner for 427
This may sound odd, but I cannot replicate the air cleaners on my car. The tunnel wedge manifold sits higher than the normal 2x4 manifolds. I have a hood clearance problem and need 2 units to replace the old ones. Rough dimensions: 7 inch diam. and 3 1/2 inch max height from flange to top nut. I have not been able to match up a KN element to replace the dirty ones on the car now. The filter element dimension is 2 1/4 high and 6 1/2 diam. Any help would be appreciated.
Paul
Old 04-30-2005, 06:46 AM
McCobra's Avatar
Cobra Make, Engine: Classic Roadsters 427 C/O w/ Dual Quads
Paul,
This thread may help.
If not, I would suggest going to Napa and telling them the exact dimensions you need They can look through their book and special order it-you'll probably have what you need in just a few days.
Good Luck
http://www.clubcobra.com/forums/show...threadid=41977
Old 04-30-2005, 01:27 PM
Thanks McCobra, I'll check out NAPA.
Old 04-30-2005, 02:07 PM
Rick Parker's Avatar
Here you go!
http://www.knfilters.com/search/univ2.aspx?ID=S0001
E4595...................2.25X 6.5
Ka ching!
Rick
Rick
Old 05-10-2005, 04:15 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
How about the 2x4 Cobra oval with a 2" filter? Cobra accessories sells them.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 05-10-2005, 09:51 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I got up in the attic and found the K&N elements I bought for my two stelling and Helling air cleaners .I'm still too high to use them buy about 1/8" to 3/16".They hold the hood up as they sit now. I'm also running a 2x4 tunnel wedge manifold.Maybe in a few years when the motor mounts sag.
My advise is with a tunnel wedge manifold I'd get a hood with a larger non traditional hood scoop.
I have two K&N elements I bought from FinishLine to fit a pair of S&H air clearners .Box says E-2570 they are 1 15/16" tall fit 8 1/2" air cleaner . I also have a 2x4 tunnelwedge intake and I.m still 1/8" to 3/16" too tall. Still looking for an air cleaner that will fit under hood and take advantage of the scoop. A tunnele wedge intake( espcially 2x4 requires) a large non tipical hood scoop.
Mike H
Old 05-14-2005, 11:52 AM
Finally found the correct size. Thanks for your suggestions and comments!
Paul
Mr. Gasket Air Filters - 6-1/2'' Diameter, 2-7/16'' Height
720-1485A
Old 05-14-2005, 01:59 PM
I was asonded how much MORE power my engine makes with the Helling and Stelling air filters removed (track use only of course).
Old 05-16-2005, 09:32 AM
No doubt the S&H air cleaners are limiters. They are nostalgic but not verry helpfull in the power department.I'm willing to pay when sombody builds an aircleaner setup for dual fours that will fit under my hood and use the scoop.
Mike H
