Old 07-28-2005, 04:20 AM
Clois Harlan's Avatar
Default Show Me where you put your .....
Fuel pressure Regulator.
I have mine mounted on my fire wall now but that will not work with my fuel rail. I need some Ideas, please.
Thanks,
Clois
"Let's roll"
"Be part of Something Good
Old 07-28-2005, 05:03 AM
Cobra Make, Engine: B&B Manufacturing,351 SVO stroker from Bennett Racing
Clois:
Mine is on the back firewall on the left hand side. Although, I setup mine to have EFI from day one which helps on the placement of everything. I have the one from Aeroquip and in one of the extra slots I have a fuel pressure gauge. Seems kind of cluttered there but you really don't have any choice if you want to do it right. I think we had to make our own bracket for everything to get attached to the firewall but it wasn't that hard.
J.A.
Old 07-28-2005, 05:53 AM
Thanks J.A.
My fuel rail along between my valve covers and carb and exits under my Expansion Tank and connects to my inlet fuel line. I need to locate my Aeroquip Fuel Presure Regulator somewhere between my fuel rail and my hard fuel line coming in from the drivers side frame. Any ideas on a good place to locate this little device where it would be easily accessable from the front of the engine? Naturally, I am at work and my pictures, camera, and Cobra are at home.
Clois
"Let's roll"
Old 07-28-2005, 07:53 AM
jwoodard's Avatar
Smile Clois........
Why not turn your fuel rail around and reroute your hard line so you can mount your regulator on the fire wall?
Jim Woodard
Old 07-28-2005, 09:58 AM
I think I tried that but the spacing on the tabs that bolts to the fuel rail doesn't line up. I may still do that and weld new tabs on the rail. I don't lik the options up front.
Clois
"Let's roll"
Old 07-29-2005, 06:39 AM
Loadco's Avatar
Cobra Make, Engine: ERA 427 SC
Here you go:
ERA #509
2003 Z06
Old 07-29-2005, 11:55 AM
Ok, I cut off my tabs for the front feed fuel rail and turned it around and welded the tabs back so it could face the rear of the car. Works great and looks pretty good too!
Clois
"Let's roll"
Old 07-29-2005, 05:00 PM
how about this? I assume you are running a single Holley
--Mike
sorry, I give up trying to post photos on this site
They bend 'em, we mend 'em.
Old 07-31-2005, 06:56 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
A picture of my set up..................
Safe Flyin, errrrr Drivin, Earl
Old 07-31-2005, 11:37 AM
Nice set-up! I modified my fuel rail so I could mount my regulator on the firewall. Everything is all done. Thanks everyone.
Clois
"Let's roll"
