Old 02-22-2006, 03:21 PM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Default Inexpensive forged FE stroker crank?
Using a 391 crank:
Offset grinding a 391 crank to BB Chevy bearing size could achieve a 4.256" stroke; by offset grinding only to a 4.250" stroke, you would assure a fully ground journal. Offset grinding may also remove enough metal so that little or no heavy metal is needed to internally balance the crank. The Chevy bearing is a bit wider, I don't know if that would weaken the crank? If this will work, I think it might be able to be done for no more, possibly less, than a Scat "Cast Steel" stroker.
Obviously, I'm looking for comments on this idea.
390 = 3.78" stroke, 2.4384 inch rod journal diameter.
BB Chevy=2.2" rod journal diameter.
.238" difference (doubled)=4.256" stroke
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
