Old 04-17-2006, 04:58 AM
Loadco's Avatar
Cobra Make, Engine: ERA 427 SC
Default Thermostat Source
Does anyone know of a source for a 195 degree "Balanced Sleeve" style thermostat (63mm).
ERA #509
2003 Z06
Old 04-17-2006, 05:45 AM
427 S/O's Avatar
"Balanced Sleeve"???, I buy the large mopar thermostat from NAPA, it comes in 190..........
Perry
Old 04-17-2006, 05:49 AM
Loadco's Avatar
Here is a link that shows the different styles of thermostats. I prefer the balanced sleeve style.
http://www.centuryperformance.com/im...ech/tstats.jpg
ERA #509
2003 Z06
Old 04-17-2006, 06:19 AM
427 S/O's Avatar
Just called NAPA and they have a 'superstat' in 192, don't know what it looks like but I'll find out this afternoon.
Perry
Old 04-17-2006, 06:23 AM
Loadco's Avatar
Thanks Perry. I think the "superstat" is the reverse poppet style. The "superstat" series is supposed to react quicker to temperature changes than the standard unit.
ERA #509
2003 Z06
Old 04-17-2006, 06:43 AM
427 S/O's Avatar
They did mention a 'fail safe', which they stop selling?.
Perry
Old 04-24-2006, 08:20 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I bought a balanced sleeve type from Summit. It's made by Milodon, model MIL-16406 but it's a 180 degree. I don't know if they have a 195 degree.
Chris
Old 04-24-2006, 10:14 PM
Rick Parker's Avatar
They are made by Robert Shaw Co and repackaged by many vendors. I know Mr Gasket is one who one sells these type thermostats, in a bubble pack on a hanging card. Below is a souce for Cobra Specific applications, good luck.
http://performanceunlimited.com/cobr...hermostat.html
Old 04-24-2006, 11:07 PM
I don't believe Robert Shaw makes their balanced sleeve stat to fit the larger diameter FE housing. I was wrong once before, however...
Dan
Old 04-25-2006, 01:53 PM
Loadco's Avatar
Robert Shaw does make the balanced sleeve thermostat for Mr. Gasket. It is available in 180 degrees but not 195 degrees. I was hoping someone knew of another manufacturer that made the balanced sleeve style thermostat to fit the FE engines (63mm) in 195 degrees.
ERA #509
2003 Z06
Old 04-25-2006, 09:33 PM
Thanks for the info. Here's the link for a Mr. Gasket 195 degree high performance thermostat. Hope it's what you're looking for.
Dan
Old 04-26-2006, 12:11 PM
Loadco's Avatar
Carnut427
That thermostat you provided the link to fits almost everything else but FE's and early Chrysler. It is smaller in diameter by about 15 mm.
ERA #509
2003 Z06
Old 04-26-2006, 02:55 PM
You'd better tell that to Mr Gasket, because according to their listing it fits '67 - '69 FEs. All I can go by is their listing. I sincerely hope you find what you're looking for.
Dan
Old 04-26-2006, 03:00 PM
Cobra Make, Engine: shellvalley 428 ford
Later FE'S used the smaller stat. 67 on up, including pick up's.
Later,Byron
Old 04-26-2006, 03:06 PM
I know later FEs use a smaller stat, but wasn't sure what years. My intake is a Tunnel Wedge, made in '68, & takes the larger stat. Must've been caught in the middle of the change.
Old 04-26-2006, 03:11 PM
Banned
Here's a source..they have the FE stat.
-Dean
Old 04-26-2006, 03:20 PM
Hey Carnut,
I think that you should let me take that POS off of your hands for you so you can get something good. HA !!! just kidding, I had one once and could kick myself for ever letting it go.
Byron
Old 04-28-2006, 06:09 AM
Loadco's Avatar
-Dean
Dean
If you look closely the 2.5" (63mm) is only available in 160 and 180 only. Thanks anyway.
ERA #509
2003 Z06
