| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
04-17-2006, 03:58 AM
MD
Cobra Make, Engine: ERA 427 SC
Thermostat Source
Does anyone know of a source for a 195 degree "Balanced Sleeve" style thermostat (63mm).
ERA #509
2003 Z06
Advertising
04-17-2006, 04:45 AM
Ga.
"Balanced Sleeve"???, I buy the large mopar thermostat from NAPA, it comes in 190..........
Perry
04-17-2006, 04:49 AM
MD
Here is a link that shows the different styles of thermostats. I prefer the balanced sleeve style.
http://www.centuryperformance.com/im...ech/tstats.jpg
ERA #509
2003 Z06
04-17-2006, 05:19 AM
Ga.
Just called NAPA and they have a 'superstat' in 192, don't know what it looks like but I'll find out this afternoon.
Perry
04-17-2006, 05:23 AM
MD
Thanks Perry. I think the "superstat" is the reverse poppet style. The "superstat" series is supposed to react quicker to temperature changes than the standard unit.
ERA #509
2003 Z06
04-17-2006, 05:43 AM
Ga.
They did mention a 'fail safe', which they stop selling?.
Perry
04-24-2006, 07:20 PM
CA
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I bought a balanced sleeve type from Summit. It's made by Milodon, model MIL-16406 but it's a 180 degree. I don't know if they have a 195 degree.
Chris
04-24-2006, 09:14 PM
Ca
They are made by Robert Shaw Co and repackaged by many vendors. I know Mr Gasket is one who one sells these type thermostats, in a bubble pack on a hanging card. Below is a souce for Cobra Specific applications, good luck.
http://performanceunlimited.com/cobr...hermostat.html
Rick
04-24-2006, 10:07 PM
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
I don't believe Robert Shaw makes their balanced sleeve stat to fit the larger diameter FE housing. I was wrong once before, however...
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
04-25-2006, 12:53 PM
MD
Robert Shaw does make the balanced sleeve thermostat for Mr. Gasket. It is available in 180 degrees but not 195 degrees. I was hoping someone knew of another manufacturer that made the balanced sleeve style thermostat to fit the FE engines (63mm) in 195 degrees.
ERA #509
2003 Z06
04-25-2006, 08:33 PM
Thanks for the info. Here's the link for a Mr. Gasket 195 degree high performance thermostat. Hope it's what you're looking for.
Dan
04-26-2006, 11:11 AM
MD
Carnut427
That thermostat you provided the link to fits almost everything else but FE's and early Chrysler. It is smaller in diameter by about 15 mm.
ERA #509
2003 Z06
04-26-2006, 01:55 PM
You'd better tell that to Mr Gasket, because according to their listing it fits '67 - '69 FEs. All I can go by is their listing. I sincerely hope you find what you're looking for.
Dan
04-26-2006, 02:00 PM
Cobra Make, Engine: shellvalley 428 ford
Later FE'S used the smaller stat. 67 on up, including pick up's.
Later,Byron
04-26-2006, 02:06 PM
I know later FEs use a smaller stat, but wasn't sure what years. My intake is a Tunnel Wedge, made in '68, & takes the larger stat. Must've been caught in the middle of the change.
04-26-2006, 02:11 PM
Banned
CA
04-26-2006, 02:20 PM
Hey Carnut,
I think that you should let me take that POS off of your hands for you so you can get something good. HA !!! just kidding, I had one once and could kick myself for ever letting it go.
Byron
04-28-2006, 05:09 AM
MD
Originally Posted by RedBarchetta
Dean
If you look closely the 2.5" (63mm) is only available in 160 and 180 only. Thanks anyway.
Gary
ERA #509
2003 Z06
