| 29 |
05-05-2006, 11:01 AM
FE pilot bushing/bearing
Might be putting my motor in soon, and I had a question about the pilot bushing.... I am using a Tremec trans on the back of my 390. Do I still use a standard OEM toploader FE pilot bushing, or is there a special one I need to get? Also, anyone have a preference between a bushing and a bearing?
Thanks!
Sal Mennella
05-05-2006, 03:34 PM
Same bushing.
And I prefer the bushing over the bearing. A bushing can wear out, but a bearing can have a catastrophic failure which doesn't end up very pretty.
Tom
05-05-2006, 03:42 PM
Thanks Tom, that's just the info I was looking for.
Sal Mennella
05-05-2006, 04:38 PM
OK
Most FE's I have seen run the standard Brass Bushing. That is what I am running with my Toploader and Dean Lampe ran with his TKO 600.
Clois
"Let's roll"
"Be part of Something Good
05-05-2006, 05:25 PM
KY
I'm running a bushing also with my Toploader. Bearings seem to fit a little more tighter....and I think that if your bellhousing isn't perfectly aligned, it could complicate things worse.
05-05-2006, 08:08 PM
OK
Cobra Make, Engine: SPF 148 with 427 SO
this thread just killed me. ask clois, I can't even talk about it!
Buzz
05-06-2006, 06:46 PM
GA
Please - do tell Clois or Buzz. I just installed a TKO and used a bearing. Am I setting myself up for trouble?
05-06-2006, 08:05 PM
The only time the bearing/bushing does anything besides keep the front of the trans shaft in line is when you have your foot on the clutch. Otherwise the front trans shaft and crankshaft are turning at the same speed. I personally see little difference between the two, but I use the bearing.
Dan
05-08-2006, 02:48 PM
OK
I just realized reading this that I did not install either and the motor has to come back out....OUCH!
05-08-2006, 03:01 PM
KY
You can't drop the tranny under the car and install it with the engine in?
05-08-2006, 03:19 PM
OK
in a SPF, you have to pull the trans tunnel to get the trans out, or you pull the engine. Since I have some oil leak issues again to fix and some gasket work..and now I am a pro at pulling that bad boy, the engine is the option I am gonna take. but man, am I hacked at myself! a few days and good as new. I am just glad that I remembered before the trans exploded.
Buzz
05-17-2006, 09:27 AM
OK
anyone have a part number for the bushing. same as the one for a 390?
Buzz
05-17-2006, 09:36 AM
KY
Buzz, I got mine from Napa. I asked for a pilot bushing for a 69 Mustang.
BRG B50HD
05-17-2006, 12:34 PM
I think ALL the FE's use the same bushing. But definitely if you asked for ANY 390 bushing it'd be right.
Tom
05-17-2006, 12:53 PM
OK
yeap...you guys are right on the money once again. thanks
Buzz
05-26-2006, 11:44 AM
bearing
I am running a sealed bearing. Keep in mind that these are not high milage cars! Also the majority of auto manufactures use a bearing currently. But you have to run one or the other.
Morgan LeBlanc
Fresno CA
05-26-2006, 12:27 PM
OK
11-27-2007, 03:40 PM
NV
Pilot Bearing
Having a hard time locating a pilot bearing for a 427 FE (most parts stores only carry the bushing). Does anyone have a part # for the bearing type?
Dan
11-27-2007, 05:57 PM
WV
I used a Federal-Mogul 303SS. Sealed ball bearing with metal shields.
Rodger
11-29-2007, 03:46 PM
NV
FYI...It ended up being Napa part 6303-2ZJ (manufactured by SKF).
