Old 01-17-2008, 06:56 AM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Default Engine project
Pond 482 Update:
Ordered-
Keith Craft Stage 2 Edelbrock Heads
Erson Rockers
Comp Cams Roller Cam
Fidanza Alum Flywheel
Ram (RAM-989551HDT) Clutch kit
Edelbrock Perf. RPM Intake
Edelbrock water pump
Summit FE billet distributor (hope it works properly)
Quick Fuel 780cfm carb (Keith likes this carb)
As advised, I am going to have Keith build the entire engine and dyno it.
Where can I get the old style Chrome stamped steel valve covers for the best price?
Anyone use a Quick Time bellhousing on a Pond block yet?
Thanks.
Old 01-17-2008, 07:13 AM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
I think you specified one of their hyd. comp cams correct? What does the cam card read? lift and duration.
I am running a 482 Pond which came off of their dyno yesterday. 601 HP @ 6100 rpm. My comp cam is 630 lift 252/262 @.050
I was told that an aluminum flywheel is not te best flywheel to have on the street. You might call David Kee to get his input.
I am not personally a fan of quick fuel however I am sure that Keith will dial it in for you. I am running a BIGS 750cfm HP
Morgan LeBlanc
Fresno CA
Old 01-17-2008, 07:33 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Geez Morgan, I think you should refuse delivery- 601 is not quite enough!
I also heard the same thing regarding aluminum flywheels on the street. I know a lot of people use them, but Gessford recommend a McLeod lightweight steel flywheel instead, which is what I used. So far so good, I have no complaints with the speed at which the motor winds up.
Replica is not a dirty word.
Old 01-17-2008, 07:45 AM
Originally Posted by RedCSX1
I was told that an aluminum flywheel is not the best flywheel to have on the street.
Not true with really light cars like Cobras. I've yet to read a post here from anyone who does not like their aluminum flywheel and there's a thread about this topic every month or so. I remember the last thread (maybe it was during the "old server" period) I wrote about how much fun it is to "blip" your throttle with an aluminum flywheel and make the engine sound like a bomb going off.
undy's Avatar
You'll be much happier with the aluminum flywheel on the 482, I am!
While it's true on the aluminum flywheel's effect on leaving torque multiplication, it is really minimized with a big inch stroked FE. The pluses earned by the aluminum flywheel far exceed the minuses. People make these statements thinking about a 302.. NOT a big inch motor. You will be very pleased with the rapid spool-up the aluminum flywheel will give you.
Too many toys?? never!
Old 01-17-2008, 09:48 AM
RedCSX1's Avatar
I have never had a problem with rapid spool up using the McLeod lightweight steel flywheel. In fact I strongly recommend a rev limiter in the range of 6000 - 6100 rpms. I am running a wide ratio toploader w/ 3.31 gear ratio.
Morgan
Morgan LeBlanc
Fresno CA
Old 01-17-2008, 09:54 AM
Good advice. I have my adjustable rev limiter mounted in the glove box. Very easy to do with your MSD unit. It just plugs in the pill hole.
Old 01-17-2008, 11:33 AM
Default What weight are you running
Hey Guys there are 3 weights for the flywheels 40,30, 20, for Mcleod. If you are doing alot of parades and slow driving the 40 lbs will work best. the 30 lb is in the middle of the road with helping remove 10 pounds off the back of the crank and help to let the motor rev quicker but also storing the torque energy to get the car moving. 20lb flywheel is best at roadracing and quick running up and down the RPM scale. With a light weight car, the 20 or 30 work better.I have run my 452 with both a 40 lbs steel and a 22 lbs aluminium flywheel. With the same motor and tuneup the car was .2 faster with less weight in the 1/4 mile. A car under 2,700 lbs doesn't need a heavy flywheel. IMO. You need to build a drive train that can hold the HP and torque. The twin street disc setup should hold just about any motor in a cobra that is under the 800HP rule and still have a light clutch pedal. Rick L.
Old 01-22-2008, 06:07 PM
Morgan,
I will email Keith and ask him for the cam specs.
