Old 09-04-2006, 05:20 AM
Cobra Make, Engine: NAF cobra, 427, 2x4's, 550 h.p.
Default 427 casting #'s THEY CORRECT?
hey guys, i am considering buying a 427 and i want to know iif these #'s are correct. i have looked in a couple of books and i don't see this one. the engine is supposed to be a 63, and from a fairlane or galaxy. the maifold #'s check out, but i can't find C3AE-J-6090-J. any comments?
LIFE'S JOURNEY IS NOT TO ARRIVE AT THE GRAVE SAFELY IN A WELL PRESERVED BODY,BUT RATHER TO SKID IN SIDEWAYS, TOTALY WORN OUT...SCREAMING, "HOLY ****" WHAT A RIDE!"
Old 09-04-2006, 07:27 AM
Cobra Make, Engine: CSX4000, 427
It should have cross bolts, if it does, then its most likely a 427 unless somebody modified a different block.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 09-04-2006, 07:31 AM
what do you mean by cross bolts?
Old 09-04-2006, 07:36 AM
bolts that go through the side of the block, near the bottom of the block above the oil pan that go into the side of the middle three main bearing caps. There has to be a picture of one here somewhere. All 427's came with them, and some very rare 406's.
Old 09-04-2006, 07:42 AM
See the 3 bolt heads near the oil pan, below the freeze plugs.
Old 09-04-2006, 07:45 AM
thanks very much..i guess i was thinking of something else. you have been very helpful and i appreciate your time.
t.c.
