| 29 |
09-17-2006, 02:25 PM
Cobra gets a heart transplant..
I'm finally finishing up the Pond 482" aluminum side oiler. The short block was built by Keith Craft and the heads were locally prepped. It's "supposed" to dyno around 670 flywheel HP with 650 lb ft of torque. The chassis dyno will tell the real story..
A new aluminum flywheel, ram clutch and TKO-600 will put the power back to the 9".
Now... I just need to finish up the whole thing.
Too many toys?? never!
09-17-2006, 02:57 PM
OH
What compression are you running?
What intake are you using?
What cam are you using?
It'll be interesting what you get on the chassis dyno.
09-17-2006, 04:05 PM
10.75 to 1
Blue Thunder 427MR 1X4, w/a worked over Holley 950hp.
Its a Comp Cam hydraulic roller custom Grind spec'd by Keith, something like.. 242/246@.050" & .649/.638 lift. Comp Cams doesn't make an off-the-shelf hydraulic roller for the FE.
.. chassis dynos make proud men humble.
09-17-2006, 06:28 PM
NE
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Undy, let me know when you get up this way sometime (Yorktown), or we could meet at Bass Pro in Hampton if you want to show it off sometime.
Sounds like a nice setup
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
09-17-2006, 06:33 PM
I'll give you a shout when I get it back on the road.
Dave
09-18-2006, 04:44 PM
NE
Unfortunately my 7 cubic inches wont make up for the 1200 lbs difference LOL but 2 stroked 427's are bound to sound good together!
09-18-2006, 04:57 PM
roger that!
10-14-2006, 11:54 AM
,,,dropping her in this Sunday.
It's getting closer.
10-14-2006, 07:16 PM
OK
Cobra Make, Engine: Looking at Superformance and Kirkham Cobras
How much does your car weigh? Any estimate of about what you think it will turn in the quarter (et and mph) with that engine? I am thinking about having keith build me the same engine. Just talked to him a couple of days ago about it.
Bill in Tulsa
10-14-2006, 07:41 PM
OK
Cobra Make, Engine: SPF 148 with 427 SO
can't go wrong with Keith...Bill, have we met? did you used to teach fire safety? I was just wondering.
Buzz
10-14-2006, 09:24 PM
OK
Keith Craft Engines
Yes, still teach fire and emergency services at Tulsa Community College. Were you a student there?
Bill
Buzz
10-15-2006, 03:34 AM
Bill in Tulsa
I haven't had it on the scales in the past but it should way about 2300 to 2400 lbs. I'm sure other Lone Star owners will chime in the to tell a more factual weight. That's a good question about ET's or 1/4 mile times.. Full slicks will be about the only way to utilize any where near the engine's potential. I would imagine in the 10s with 130+ ETs. Driver skill will play a major part in the equation too. As the ol' saying goes... "What does a 300 hp and a 700 hp turbo Supra have in common?" ... "12 second quarter mile times..." I can tell you that I was extremely impressed with Keith's quality of machine work and the attention to detail. Every part, bolt and gasket was the crem-de-la-crem!
Dave
