Second off, the Pond block, in addition to having siamesed cylinders, has a bulged block around each cylinder that adds material (and strengh and weight) to the block. So strengthwise, it goes: bored-Original, Original, Genesis, Shelby, Pond. Ford DID want it that way, at least initially. The FE was a thinwall casting, state of the art at the time, that weighed just enough but not too much. If you want an engine that was cast using 19th century theory, look to the 'elephant' hemi where the block was cast sooo thick that you could bore it probably an extra 1" per cylinder (JK). That was bad for real life usage in passenger cars, but great on a straight line drag strip. Personally, I'd get a Pond, an aluminum Pond, a Genesis, an aluminum Genesis in that order of preference. You get the benefits of a design that has been updated for strength, that looks very close to the original, that will take all original parts as bolt-on's, and that are better than the originals. The Shelby just looks wrong. It might be 'better', it just looks wrong. |
Thanks to everyone for all of the input, as it is helping me get closer to making a final decision. What it has come down to is this; if the price were identical, which engine would you rather have, an original 428/FE or a new 427/FE Genesis?
Unless you are going for dead nuts originality, once you make the switch to a good quality aftermarket block you will never go back. My $.02
jack |
I don't think the price will be the same, but if it was I would still take the 427 FE. The 427 Keith Craft is building me is with the Pond cast block. Just my .02 worth!:MECOOL:
For what it is worth, I'm in the process of pulling apart a 95 4.6 DOHC modular. I know, I know, it not an FE, but bear with me a second here, as it becomes relevant. I haven't got it apart enough to measure the bores, but there are no ridge lines at the top. This engine has 105K miles on it. By feel I'm guessing less than 0.010 wear as I cannot feel anything anywhere, and you can still see the hone lines. Here is where it becomes relevant. This is an aluminum block with steel sleeves. I think the steel sleeves hold up much better than cast iron. This is a plus for a modern aluminum FE block, assuming they use steel sleeves rather than cast iron.
Additionally aluminum conducts heat better than cast iron, so cooling and even temps are much improved. However with the aluminum there is much more thermal expansion (think 4 times not sure). In my mind a large aluminum block push-rod engine almost has to have hydraulic lifters. With solids the valves would be mighty loose cold. Also the main bearing clearances change a bunch from cold to hot on an aluminum engine. Warm up is even more critical on an aluminum motor. Hope that gives some food for thought on aluminum verses cast iron. |
Not wanting to hijack this thread but wondering about a local motor - 427 side-oiler, "built right" and available for $8,000 Canadian.
This is a lot of money for this motor isn't it? |
But what does your phrase built right really mean? |
What's even more puzzling to me is the people who declare they MUST have a 1960s original 427 block vs. a new aftermarket FE block in their replica Cobra. :LOL:
Ouch
Ernie, you still out there? The snake must have his tongue:LOL: **) |
Dan |
Just the opposite, the valve lash is very tight when the engine is cold, about 0.013" for an all aluminum FE. Solids are not a problem. Quote:
because of GM's design, the 400 with siamesed cylinders had cooling issues. Steam pockets were created under the deck because there was no flow around the cylinders at that point.
supposedly, that is not an issue with the Genesis blocks. everyone is implying that siamesed cylinders can be bored to the extreme of a .10 wall shared by two cylinders. Not so. a siamesed cylinder works better generally because it is thicker overall, stiffer, less prone to distortion. it IS connected to the next cylinder(s) along a line though. Heat these cylinders up, and constrained as they are by their neighboring cylinders, you'll get out-of-round distortion. bore these connected cylinders and you'll experience MORE of this out-of-round distortion than you would if the cylinders were free 360* around. So siamese cylinders CAN be good, just don't take all that metal as a free pass to bore the daylights out of them or you'll have ring seating (and other) problems like you wouldn't believe. |
NM at all, this time
While various truck and heavy duty engines earlier had used siamesed cylinder design for low RPM applications, the Hudson 308 inline 6cyl developed in the late '40's and first installed in the Hornet line in '51 had siamesed cylinders and was intended to be capable of all-out sustained high RPM racing. This application most closely tracks our interest in this forum and is probably one of the first American applications of cylinder siamesing as we would use it. The Hudson 308 engine was a bored version of the 262ci engine which required strengthening as the original design limitations were exceeded. The high chromium content of the block alloy minimized cracking of the siamesed cylinders under ordinary use conditions but an overheated block would occasionally crack under severe (race) use. Despite this, the Hornet was THE car to beat in NASCAR (a brutally harsh racing environment in those crude dirt track days) from '51 up into '54. Anyway, the best overhead valve V8-equipped Olds and Mopars found it very difficult to beat the 308ci (FLATHEAD no less) 6 banger in a Hudson Hornet. The other marques (ESPECIALLY Chebby) were completely outclassed and not even close to being serious contenders. Doc (The Fabulous Hudson Hornet) Hudson sends his kind regards!;) |
Disappearing marques.....
1957. Hudson might have outclassed the other marques on the racetrack, but they certainly didn't outclass them in the showroom. ....Fred |
Interesting point, Fred. Actually, Hudson truly died in '54 (I happen to own one of the very last true Hudson Hornets, made in the last week before the line shut down for good in '54)... the Hudson nameplate simply got slapped on Nash cars until '57, except that the 308 did soldier on for a while past '54. Just goes to show that a marque with recognized "Milestone" stepdown design, topnotch performance and--for the times--safety as well as some of the most beautiful body and interior styling of the day simply couldn't compete with the low costs, hucksterism, and market power of Great Monster.:CRY: The fact remains, if I may nudge us back to the topic of siamesed engine cylinders, that successful siamesing of cylinders in a high performance engine pushing or exceeding original design limitations WAS done well before Ford or GM would have considered it in subsequent DECADES!:cool: |
Bragging rights!
I put a 66' 427fe in my car for the bragging rights.
I could have built any number of other engine combo's for less $$. But just look at this and imagine saying "Yes, it's an original 1966 FORD 427fe side oiler"! http://www.clubcobra.com/photopost/d...aOct06_008.jpg I did, and pony'ed up for the bragging rights!;) jdog P.S. You can't take it with you, might as well enjoy it while your still here!%/ |
Jdogy - ...and then you put THAT air cleaner on it. :confused: Contradictory comes to mind. Yes, it still does look nice though.;)
have to wonder about the internals...original pistons? rods? valves? cam? water pump? originality is such a loose word. getting back on track, do the Genesis block. highly recommend using a builder that's built a couple of them before. |
| All times are GMT -7. The time now is 01:56 PM. |
