09-25-2006, 08:10 PM
az
FE oil leaks
Many people have told me to expect oil leaks fron FEs. Is this true?
double ugly
09-25-2006, 08:30 PM
Does a bear sh..... Nevermind
09-25-2006, 08:49 PM
Cobra Make, Engine: ERA 427" 351W
They do tend to leave little spots on the floor no matter what you do. Pan, valve covers, breathers, etc. But that's the price you have to pay for a Viagra substitute.
Al W.
09-25-2006, 09:23 PM
Mine doesn't leak, period. I did take extreme pains to make every sealing surface secure. All though many do leak, it's really just a matter of putting it together right in the first place.
There are tricks to getting it right and some parts are tougher than others. Like stamped steel valve covers are harder to seal than alloy valve covers (there more stiff). Using 'just enough' silicone seal is better than using to much (on many levels). CLEAN surfaces are a must.
Now that rear main seal, I lit three candles, threw salt over my shoulder and knocked on wood before I started that one.  Whew, got lucky!
09-25-2006, 10:29 PM
It is not "Permatex" as we know it, but is manufactured by them.
09-25-2006, 10:32 PM
09-25-2006, 10:40 PM
Hmmm, I didn't use Permatex, but it IS a good product.
09-26-2006, 03:51 AM
Ont
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
The Brits have a saying for their bikes, that applies to Cobras. "They aren't leaking oil, they are just marking their territory!"
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
09-26-2006, 05:38 AM
09-26-2006, 06:47 AM
Excaliber, You are fortunate! The only leak I have now is the breathers. Anyone have a voodoo trick for that?
Al W.
09-26-2006, 07:35 AM
Al,
I don't know if this would mess up your set up or not, but could you get the breather caps with the outlet on top and run a hose to some point in the intake where it would pull the oil vapor back inside and burn it like in the closed systems? I am not to familiar with the injections set ups and don'tknow if it would mess them up or cause other problems.
09-26-2006, 09:50 AM
Of course I only have about 4000 miles on my motor, it's to early to tell where the 'leaks' WILL come from down the road!
While most prefer the classic black paint for the block, I went with blue (also 'correct') for two reasons:
1. Brighten things up a bit under the hood.
2. Easier to spot engine leaks and nip it in the bud!
09-26-2006, 10:41 AM
Ernie,
My block is blue and even with the darn dye I can't find where the leak is. I can easily spot where the wind has blown oil, but I think the leak must have to have pressure to happen. Now it looks as if I may also have a water pump starting to leak a little. I am tired of cars and their problems. Just once I would like to go a few months without something happening.
09-26-2006, 11:16 AM
az
How much of a leak do some of you feel is acceptable? Mine doesn't leak at all unless I get the oil temp. up to operating temperature.(80C) When I let the car set overnight I find a puddle about the size of two silver dollars.
double ugly
09-26-2006, 11:24 AM
Well that is a lot larger than mine. I find about two drops per night on the floor. Sometimes three or four drops just after I drive it and the oil is hot. In fact I just called an engine builder here and he is going to try to work me in next week so we can put it on the lift with it running and see if we can spot where it is coming from and he said he would also look at the water pump too.
