November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-23-2006, 09:46 AM
undy's Avatar
Default FE expansion tank question..
I'm contemplating installing an expansion tank on my 427 S/O in my Lone Star to add a little more "correctness" to it. I'm concerned about tank to hood clearance issues. Any Lone Star owners with a FE and an expansion tank out there??
Too many toys?? never!
Old 10-24-2006, 06:08 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
Undy;
I have an original tank, set up for an FE, that I was going to modify for my 351 but I have too much stuff in the way. If you want to give it a shot, let me know.
Bill Stradtner
Old 10-24-2006, 03:36 PM
undy's Avatar
Originally Posted by sllib
Undy;
Bill Stradtner
Bill,
Looking at the pictures of standard OEM FE passenger car expansion tanks (outlet on the passenger side) it would seem possible to unsolder the bottom pipe and bracket, reverse it 180 deg and resolder it for a driver's side outlet. If this is possible (looking for answers on this one???) I would definately be interested in your tank.
Dave
Old 10-24-2006, 04:06 PM
Jimi G's Avatar
Dave,
You could do that without a problem, depending on what the tank is made of, you could either solder, silver solder, or braise it.
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 10-24-2006, 04:39 PM
double ugly's Avatar
The original question hasn't been answered and I can't help with the clearance issue. I can add, however, that the brass expansion tanks tend to leak unless you're very lucky. After my limited experience with them (three re-solders and still leaking) I decided to go with a stainless steel tank from Southern Automotive. No more leaks.
John
double ugly
Old 10-24-2006, 04:55 PM
Rick Parker's Avatar
The type of solder typically used does not have enough Tin in it to provide any structural strength. The vibration shakes it apart, especially with the firmer suspension and radical cams that Cobras tend to posess. Change to Silver Solder applied correctly and alot of the problems will go away.
Rick
Old 10-24-2006, 06:18 PM
undy's Avatar
As an HVAC contractor I do a lot of silver soldering. I've got some 45%, 15% and some 5% (econo solder jobs.. ) on my truck. With a very thin wall brass tank it'll be somewhat difficult to control temps with the comparitively high melting point of silver solder. The thin brass tends to warp and buckle, sometimes even splitting. I can soft solder with 95/5 (tin antimony)which has a shear strength approaching siver solder's.
Dave
Old 10-24-2006, 09:37 PM
2KWIK4U's Avatar
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Dave
No problem with clearance on the LS. I used the Dove aluminum tank with the drivers side outlet with no issues. Theres pics in my gallery if needed.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
Old 10-25-2006, 09:49 AM
Jimi G's Avatar
Since it is brass, your bet bet would be to braise it then, you will get good strength out of the weld, and it is a low temp. process. But the stainless steel one might be your best bet, they probably have one already configured for the drivers side. jimig@standardtransmission.com
Old 10-25-2006, 11:50 AM
undy's Avatar
Thanks to all for offering help (one of the board's strong points) ...
Southern Automotive has a really good looking polished, 100% stainless steel expansion tank that duplicates that factory stamping v-e-r-y closely. It's $425 plus shipping. I went that route... I guess you get what you pay for.
I really don't need another do it/mod it yourself project anyway.
Dave
Old 10-25-2006, 12:19 PM
Jimi G's Avatar
That will work Dave, sometimes that is the easiest route, and a whole lot less of a headache. jimig@standardtransmission.com
