Old 10-29-2006, 09:45 PM
Default Twist -In Breather
I am having difficulting finding the twist in valve cover breathers. The push in types are easy to find; however, they cannot be used because of the open tab on each side of the valve cover breather hole.
Any suggestions?
Old 10-30-2006, 05:06 AM
Clois Harlan's Avatar
Sure they can, I have been using K&N for years and I have absolutely no leakage or blow by. I use the rubber push in type on my drivers side valve cover and a rubber gasket with a PCV valve in the passenger side hooked up to the intake. I also have the breather on the back of my intake that helps a lot too.
Clois
"Let's roll"
"Be part of Something Good
Old 10-30-2006, 06:42 AM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Jegs carries the twist in valve cover breather, you can usually find them listed in the engine dress up section of the catalog.
Old 10-30-2006, 02:30 PM
Default Twist in Breathers
I found these on ebay and remembered your thread...........
Ford 390-427-428 Twist In Chrome Breather Cap
Item number: 110047349918
