Old 02-06-2007, 01:11 PM
DougD's Avatar
Default Fluidamper and which pullies?
I'd like to put a Fluidamper harmonic balancer on my 427. Will this affect the alignment of my pullies for the water pump and alternator? I'm going for a stock look, so aftermarket March or similar pullies would not be my first choice. What pullies do I need to line up with the new balancer?
Old 03-06-2007, 07:32 PM
Cobra Make, Engine: LSC 462
if you use the Fluidamper harmonic balancer you will need to have your motor rebalanced. i put one on mine and they had to add 19grams to my crank
Old 04-09-2007, 12:24 AM
82ACAUTOCRAFT's Avatar
Cobra Make, Engine: AC Frua, FE Side Oiler
I don't understand, the 427 is balanced internally, if done properly, as long as you harmonic balancer has zero balance it should be fine. Correct me If I am wrong but the Fluidamper is actually designed for the 385 engine, it has to be machined to go on an FE, correct?
Old 04-09-2007, 06:34 AM
DougD's Avatar
I decided to go with the original balancer. Now I'm looking for the correct timing pointer which is missing. Thanks dragon462 and 82acautocraft for the replies.
