Old 03-16-2007, 09:42 AM
Cobra Make, Engine: ERA 675 - 427 SO
Default Need help with solid lifters
Hello everybody. I’m having trouble finding the correct solid lifters for my 427. I am in the process of converting to a Jesel roller rocker system. I didn’t realize at the time that the Jesel system doesn’t get oil to the rockers using the traditional method of up through heads, then through the rocker stands and finally out through shafts to the rockers. Jesel uses hollow pushrods to transfer the oil from the oil galleys via the lifters. Anyway, my 427 service block is a “juicer” and it has the extra lifter oil galleys so there doesn’t appear to be a problem getting oil to the lifters.
Where I’m having trouble is locating solid lifters for the 427 that have the oil transfer holes that are needed to get the oil into the pushrods. So here’s my questions:
1. Does anybody know of a solid lifter for the FE with the needed oil transfer oils?
2. Could I use the Comp Cams 833-16 solid lifter for the 302-351 & 460-429 engines? This lifter has the correct oil holes and is the correct .874 diameter. It is about .150 longer, but since I need new pushrods anyway, I would just order the shorter pushrods.
Thanks for the help, Tom
Old 03-16-2007, 10:49 AM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Tom,
You should call comp cams tech. service. Just be sure to give them as much accurate information about your setup as you can.
Old 03-17-2007, 01:11 AM
cobra's Avatar
Cobra Make, Engine: ERA 427 SC # 571, 472 Shelby aluminum "stroker " CSX # 299 from Gessford, 48 IDA Weber carburetors from Jim Inglese
Wink
Tom
Give a call to George Anderson at Gessford (http://www.gessford.com)
I'm sure he can help you.
Greetings from Switzerland
Walter
Walter
http://www.kreuchi-auto.ch
